    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 518.2k Views 108 Watching
    • brookefoxB Offline
      brookefox
      tak2hata, Thanks very much for this promising set of tools. I hope you find the time to make the videos larger and maybe more complete.
      I tried copying and slightly altering the wall to have a baseboard on both sides but this seems to 'break' the proper corner corrections you have made the program perform. I see all your multi-walls are one sided; do they have to be? Could the standard application methods be adapted to trimming around window or door openings?
      ~ Brooke
        sags
        thanks... πŸ‘
          josephcase
          I apologize if this is not correct area,
          I need help.. I'm tasked to create two different
          size CORRUGATED MULTI-PLATE pipes. The first has dia
          of 9'6" IS using total 6 plates @5 gage to complete 1 ring. The
          second is 16' IS using 8 plates @5 gage. It appears that your
          toolkit allows making FLAT roofing products EXCELLENT! Can
          it make the sections I need for circular multi plate corrugated pipe?
          The holes and length/width are no issue but curved as opposed to
          flat is. Please advise or point to tutorial for topic. Thanks Joe
            tak2hata
            Hi,Joe.
            I think that your proposal is difficult in this plugin.
            I think Chris Fullmer's Shape Bender is help you.
            http://forums.sketchucation.com/viewtopic.php?t=18210#p147395
            Hi,SU Fractal and Beginer.
            The File System of ruby in sketchup(windows) can not work well with path include the original characters of the language.
            I tried the many method ,but I could not find good solution.
            So the csv file about profile list locate the suitable folder whitch do not include the special characters.
            This is as hard as possible.
            Thanks.
            by TAK2HATA
              SUFractal
              tak2hata:
              Today (all of a sudden) the "steel column" tool stopped working. All of the other tools appear to be working fine. I have not changed any of the scripts or files associated with this plugin for quite a while.
              When I click on the steel column icon, a window for selecting member sizes does not appear.
                tak2hata
                @sufractal said:
                tak2hata:
                Hi,SUFractal.
                well,I do not have a point to which it occurs.
                So I want to see the ruby console on your sketchup.
                Show "Ruby console" from "Window" menu.
                Start Building structure tool"Steel Column".
                Copy the message shown in ruby console.
                And post it.
                I will see and consider the problem.
                by TAK2HATA
                • kenK Offline
                  ken
                  @sufractal said:
                  tak2hata:
                  This has happen to me also. I found that if you go to the plugin menu and clear defaults it will start working again. At least on my computer that works.
                  Ken
                    SUFractal
                    @sufractal said:
                    tak2hata:
                    Ken
                    Genius! Thank you Ken, it worked.
                      kob42823
                      Excellent πŸ‘
                        andyomis
                        I am working with Sketchup 8 pro on a mac. The .rb file and the folder are in the right place and the tool bar is there. However when I open to select a tool the tool window is blank. All the appropriate file paperer to be in the folder. Any suggestions?
                          andyomis
                          Further to my earlier post today I now have toolbar icons etc. However I cannot select next point. Help!
                            tak2hata
                            Hi,Everybody.
                            I update this "Building structure tool" to version 1.0a.
                            Many improves added.
                            Hi,andyomis.
                            I want to know ruby console error message in your problem.
                            So you open ruby console window and use Building structure tool.
                            There will be messages.
                            Copy the massge and reply here.
                            I will see.
                            Or,Install new version with RBZ file.
                            In SKetchup Preferences menu.Click "Install Extention".
                            And select RBZ file.
                            That need profile list file ,too.
                            Download each files.
                            Thanks.
                            by TAK2HATA
                            • Z Offline
                              ZFRPS
                              Dear tak2hata:
                              Your this plugin very very useful for **BIM**,I will always support you!
                              But...Why to remove will general model transformation into your unique model functions?
                              you now allow the section type is not very rich![q01.jpg](/uploads/imported_attachments/rGQI_q01.jpg)
                              Or if you can tell how we can increase the section type!
                              Undeniable, you are doing now is a profound things for **BIM**.
                              THANKS AGAIN!
                              sketchup is bim
                              • Z Offline
                                ZFRPS
                                Depressed!
                                Early versions of the dot, line automatically created according to the function also is gone!!
                                sketchup is bim
                                  tak2hata
                                  Depressed!
                                  Hi,zfrps.
                                  I think your sketchup was missing profile list filepath.
                                  Profile schema keeps working well.
                                  In this version the profile list is not included in main file.
                                  Because installing guard from overwriting the already existed profile list you changed.
                                  So you must set your profile list file path,if you delete your profile list with building structure tool folder.
                                  The generating automatically from edges with "apply" button.
                                  Please watch video I added in first thread.
                                  Thanks.
                                  by TAK2HATA
                                    SUFractal
                                    takshata:
                                    I just installed your new plugin, but all of the boxes in the dialog window are filled in 'black' and I cannot see the values inside of them?
                                    Thanks.
                                      andyomis
                                      Tak2hata san
                                      Thank you for your reply. I have now loaded the new .rbz file.
                                      When I open the BST tool options there are no profiles listed.
                                      When I select CLASS I get the following message "how to edit_pflist.pdf is not Exists. So read from default.
                                      When I select OK I get the following message "could not find profile list. So select your profile list file"
                                      There is no CSV file or xml file that I can select.
                                      When I cancel the select file dialog some default profile appear.
                                      If I change the class then I get the same sequences of messages again.
                                      When I look at the other tabs in the BST tool options the box backgrounds are black so I can't see anything.
                                      Can you guide me to the csv or xml file. Thank you
                                        tak2hata
                                        @sufractal said:
                                        takshata:
                                        Thanks.
                                        hi,SUFractal.
                                        I am out now.
                                        So I will test it later.
                                        But I tested this verison in mac os yesterday.It was no problems.
                                        Please tell me you install from "RBZ"? or "ZIP".
                                        Thanks.
                                        by TAK2HATA
                                          troypiggo
                                          @sufractal said:
                                          takshata:
                                          Thanks.
                                          Sounds like this problem: http://forums.sketchucation.com/viewtopic.php?f=11&t=45382
                                          This is not my signature. I type it at the end of every message for quality control.
                                            tak2hata
                                            @troypiggo said:
                                            @sufractal said:
                                            takshata:
                                            Thanks.
                                            Thanks troypiggo.
                                            It is very helpful information.
                                            I will add html code about text background color to white.
                                            Thanks.
                                            by TAK2HATA
                                            • 16
                                            • 17
                                            • 7 / 17
