    Free PDF to DWG converter?
    7 Posts 6 Posters 2.7k Views 6 Watching
      Stu
      I think this is probably wishful thinking....does something like this exist?
      At the moment I'm using a version of AutoCad that was released before PDFs were even dreamed of πŸ˜„
      I probably should buy a version of IntelliCad but if there is actually a free converter [rather than a trial version] I would be happy with that.
      Thanks Guys
      http://www.landesign.com.au
        There are a few free online PDF2DWG converters...
        http://www.convertpdftodwg.net/resources/convert-pdf-to-dwg-online-free.html
        http://www.convertpdftodwg.net/resources/free-pdf-to-dwg-converter.html
        Let us know how you get on...
        • emerald15E Offline
          emerald15
          http://forums.sketchucation.com/viewtopic.php?f=179&t=46254#p413549
          we've just been discussing this
            http://www.roitsystems.com/eido/index.pl
              AZPilot
              This program works really well for me. It's a paid program but the demo works and all it does is put some text on the dxf file. You can then delete the text. If you pay for it of course there's no text.
              PDF 2 DXF
              Convert PDF files with CAD drawings inside into DXF files.
              (www.cadkas.com)
              Todd
              Chandler, AZ
                d12dozr
                I've had good luck with this one: http://www.cometdocs.com/
                http://goo.gl/f7ooYh
                  Stu
                  Thanks Tig and Fiona,
                  As I suspected the free stuff is pretty scratchy, if it works at all... but I did find Able2Extract
                  http://www.investintech.com/downloads.htm
                  Does a good job, converts to DWG as well as DXF, and its possible to set units, line width and scale.
                  For a $100 it seems reasonable value
                  Edit:....And thanks Rich and All for the links below
