    Vignetting or fading a view?
    layout
    5 Posts 3 Posters 1.0k Views 3 Watching
      troypiggo
      Any tricks on creating a vignetted view? I saw a style in SU that does it, but when I use that in the view's style, I couldn't figure out a way to have it completely faded by the time it got to the edges of the view window, so it cut off suddenly.
      This is not my signature. I type it at the end of every message for quality control.
        This is more of a Style than Layout question...
        All a vignette-style does is apply an image over the whole view which has a clear center and edges gradually becoming white [or any color used].
        You simply make a transparent png in Gimp or Photoshop with whatever gradation/colors etc you want and use that as the Watermark - with suitable setting in the appropriate Style edit pane...
        Some Fog attached to the Scene-tab can also fade the image into the distance...
        v5 Style _ vignette.style
          troypiggo
          Excellent. Thanks for the tips. Will look into watermarking.
          • shuraS Offline
            shura
            here is an inspiring example on YT for how fog is used for fading:
            have a look at minute 4:28.
              troypiggo
              Thanks mate. Had seen that video. Sonder's work is very impressive and inspirational. Been admiring it for a while.
