    Move vertex using absolute coordinate
    5 Posts 3 Posters 2.7k Views 3 Watching
      metaclay
      Hi, i'm new to ruby. I'd like to know how to move vertex using absolute coordinate ? i used transform_by_vectors and transform_entities , they only provide relative transformation.
      Thanx
        Calculate the final destination based on the original position.
        vector = vertex.position.vector_to( new_position ) entities.transform_by_vectors( [vertex], [vector] )
          trt=Geom:Transformation.translation(vector)
          then
          obj.transform!(trt)
          moves the object by length of the vector in the direction of the vector.
          trn=Geom:Transformation.new(point)
          then
          obj.transform!(trn)
          moves the object to the specified point irrespective of where is is beforehand.
          To move an array of vertices you can use
          entities.transform_entities(trt, vertices)
          when they'll all shunt over in the direction of vector by the length of vector.
          If you have a collection of different vectors for different vertices then use
          entities.transform_by_vectors(vertices_array, vectors_array)
          You don't want to to apply a 'move' trn type of transformation as they'd all end up coincident !
          If you have an array of 'vertices' and a matching array of their new absolute 'positions'... then use an iteration...
          vertices.each_with_index{|v, i| pt=positions[i] tr=Geom:Transformation.new(pt) entities.transform_entities(tr, v) }
          Each vertex in turn is then assigned the new position [point]...
            Very inefficient! You want to transform all at once.
            What I do for vertex tools is by using transform_by_vectors
            <span class="syntaxdefault"><br />vectors </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[]<br /></span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_with_index</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">vertex</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> i</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  new_position </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> new_positions_array</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">  vectors </span><span class="syntaxkeyword"><<</span><span class="syntaxdefault"> vertex</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vector_to</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">new_position&nbsp;</span><span class="syntaxkeyword">)<br />}<br /></span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform_by_vectors</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> vertices</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> vectors </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
            At all times try to use bulk methods that updates multiple entities at the same time. Even for selections, don't use add/remove within an iterator - use a cache array and update in bulk afterwards. It's the difference between minutes and seconds.
              That is a much more efficient way of doing it [transforming [or erasing] entities en mass is often preferable]... But in my defense... the title of the post is move **vertex**... NOT move **vertices**... - so there is probably no significant benefit in the en mass way when he's moving just one or two or three vertices - obviously if a whole load of things are changing a time lag will be noticeable...
