    How to read the measure tool values and what variable ?
    3 Posts 3 Posters 306 Views 3 Watching
    • Y Offline
      youthreewire
      I have a query regarding the measure tool. The measure tool as you know is for measuring the distance between tow points. Now I want to know in which variable is it stored and if more than one what is the variable array for it? I want to read it through code in Ruby. Please let me know.
        Aerilius
        It is stored in "no" variable that could be accessible with Ruby. The native measurements tool is not written in Ruby but in C code and the only linkage between SketchUp's internal C code and Ruby are the methods of the Ruby API.
        Even if we had access to the C code objects, it depends on the variable scope whether the measurements tool exposes its internal methods and variables.
        Sometimes a solution is to rebuild a native tool with Ruby (or only the part that you need).
          Look at the linetool.rb example that ships with Sketchup.
          All you need to do is use the two picked points and length=point1.distance(point2) without drawing the line at all.
          You can then 'format' the result as desired...
