    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 33.8k Views 16 Watching
    • tbdT Offline
      tbd
      yes. my old example did that. best is to check the DLL imports section to see what functions it requires
      http://plugins.ro
        Ah, the Pelles C project! Is it possible to use to to just compile the C source without creating a project? (just trying to find a solution without creating too many extra project files.)
        • tbdT Offline
          tbd
          the .ppj file is just a collection of commands. you can easily convert it to a .bat file if you dont want to have extra files (remember to create the .def file for the .dll link)
          http://plugins.ro
            Do you remember the cause of the C:\ruby\src\ruby-1.8.6-p111\missing.h(71): error #1050: Redefinition of macro 'isinf'. error? And can you explain what your workaround actually do?
            Trying to set up a project myself so I actually understand this.
              And why is the macro redefinition just a warning for this guy, but an error in Pelles C?
              https://github.com/barrie0482/rrdruby_win32_build/wiki
                hm... there is an msvcrt-ruby18.dll in the SketchUp folder - can I make my Visual Studio C++ project rely on this instead? So when the C Extension loads under SketchUp Ruby the runtime is there - installed by SketchUp. ??
                  isinf is already defined in PellesC libraries so there is no need to include that file again.
                  But I am not including it myself - it's an error that comes from the Ruby missing.h file... :S
                  Building hello_world.obj.
                  Use <stdlib.h> instead of non-standard <malloc.h>
                  C;\ruby\src\ruby-1.8.6-p111\missing.h(71); error #1050; Redefinition of macro 'isinf'.
                  *** Error code; 1 ***
                  Done.
                    http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version.
                    When compiling with Pelles C, right? Any way to make VC++'s nmake rely on the bundled SketchUp CRT instead of the VSC++ CRT? (splitting my quest into two projects here...)
                    • tbdT Offline
                      tbd
                      http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version. also you can copy the msvcrt-ruby18.dll in your dev directory to be picked up when debugging outside Sketchup (which I hope you do, otherwise dev time is slooooow)
                      http://plugins.ro
                      • tbdT Offline
                        tbd
                        that's why you need to have #define HAVE_ISINF 1 in your code, so that Ruby will not double include
                        compile with the same VC πŸ˜„ or dont link any CRT and use a replacement static lib (there are some minimal libs on the net)
                        http://plugins.ro
                          _MSC_VER == 1200 = MVC 6, right? Can you get hold of that version any more?
                          Here you lost me. "linking"... another concept I need to learn.
                            That is still greek to me... The only thing I compiled before these Ruby C Extensions where Visual Basic 4 applications... πŸ˜’
                            • Dan RathbunD Offline
                              Dan Rathbun
                              As .. in statically linked, or dynamically linked.
                              (Hence the DLL and dylib, means Dynamically Linked Library.)
                              πŸ’­
                              I'm not here much anymore.
                              • tbdT Offline
                                tbd
                                if you want to have fun - http://www.benshoof.org/blog/minicrt/
                                http://plugins.ro
                                  hmm... so I could take my C Extension made with VC++'s nmake and statically link the RT - avoiding having to bundle it or require the users to install any additional RT?
                                  • tbdT Offline
                                    tbd
                                    yes. the dll were created to solve the duplicate code problem but they created another problem - the DLL hell.
                                    but for SU extensions having a couple of kB duplicated for the CRT is ok. also it makes the installing easier.
                                    http://plugins.ro
                                      And from I gathered of the Wiki article, then the DLLs are statically linked they can link just the part of the library required. ??
                                      Now I need to figure out how to statically link the CRT. Is it as simple as a compiler flag?
                                        -MT instead of -MD seem to be the one...
                                        http://stackoverflow.com/questions/8463073/nmake-vc-2010-compile-without-msvcr100-dll-depends
                                        http://msdn.microsoft.com/en-us/library/2kzt1wy3%28v=vs.80%29.aspx
                                          Changed compiler flag from -MD to -MT
                                            On a real world project, Vertex Tools:
                                            I can live with that. πŸ˜„ Now it "just works" on even the freshest of systems.
                                            • 7 / 9
