    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 50.9k Views 16 Watching
      yes. my old example did that. best is to check the DLL imports section to see what functions it requires
      Ah, the Pelles C project! Is it possible to use to to just compile the C source without creating a project? (just trying to find a solution without creating too many extra project files.)
      • tbdT
        tbd
        the .ppj file is just a collection of commands. you can easily convert it to a .bat file if you dont want to have extra files (remember to create the .def file for the .dll link)
        http://plugins.ro
          Do you remember the cause of the C:\ruby\src\ruby-1.8.6-p111\missing.h(71): error #1050: Redefinition of macro 'isinf'. error? And can you explain what your workaround actually do?
          Trying to set up a project myself so I actually understand this.
            And why is the macro redefinition just a warning for this guy, but an error in Pelles C?
            https://github.com/barrie0482/rrdruby_win32_build/wiki
              hm... there is an msvcrt-ruby18.dll in the SketchUp folder - can I make my Visual Studio C++ project rely on this instead? So when the C Extension loads under SketchUp Ruby the runtime is there - installed by SketchUp. ??
                isinf is already defined in PellesC libraries so there is no need to include that file again.
                But I am not including it myself - it's an error that comes from the Ruby missing.h file... :S
                Building hello_world.obj.
                Use <stdlib.h> instead of non-standard <malloc.h>
                C;\ruby\src\ruby-1.8.6-p111\missing.h(71); error #1050; Redefinition of macro 'isinf'.
                *** Error code; 1 ***
                Done.
                  http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version.
                  When compiling with Pelles C, right? Any way to make VC++'s nmake rely on the bundled SketchUp CRT instead of the VSC++ CRT? (splitting my quest into two projects here...)
                  • tbdT
                    tbd
                    http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version. also you can copy the msvcrt-ruby18.dll in your dev directory to be picked up when debugging outside Sketchup (which I hope you do, otherwise dev time is slooooow)
                    http://plugins.ro
                    • tbdT
                      tbd
                      that's why you need to have #define HAVE_ISINF 1 in your code, so that Ruby will not double include
                      compile with the same VC 😄 or dont link any CRT and use a replacement static lib (there are some minimal libs on the net)
                      http://plugins.ro
                        _MSC_VER == 1200 = MVC 6, right? Can you get hold of that version any more?
                        Here you lost me. "linking"... another concept I need to learn.
                          That is still greek to me... The only thing I compiled before these Ruby C Extensions where Visual Basic 4 applications... 😒
                          • Dan RathbunD
                            Dan Rathbun
                            As .. in statically linked, or dynamically linked.
                            (Hence the DLL and dylib, means Dynamically Linked Library.)
                            I'm not here much anymore.
                            • tbdT
                              tbd
                              if you want to have fun - http://www.benshoof.org/blog/minicrt/
                              http://plugins.ro
                                hmm... so I could take my C Extension made with VC++'s nmake and statically link the RT - avoiding having to bundle it or require the users to install any additional RT?
                                • tbdT
                                  tbd
                                  yes. the dll were created to solve the duplicate code problem but they created another problem - the DLL hell.
                                  but for SU extensions having a couple of kB duplicated for the CRT is ok. also it makes the installing easier.
                                  http://plugins.ro
                                    And from I gathered of the Wiki article, then the DLLs are statically linked they can link just the part of the library required. ??
                                    Now I need to figure out how to statically link the CRT. Is it as simple as a compiler flag?
                                      -MT instead of -MD seem to be the one...
                                      http://stackoverflow.com/questions/8463073/nmake-vc-2010-compile-without-msvcr100-dll-depends
                                      http://msdn.microsoft.com/en-us/library/2kzt1wy3%28v=vs.80%29.aspx
                                        Changed compiler flag from -MD to -MT
                                          On a real world project, Vertex Tools:
                                          I can live with that. 😄 Now it "just works" on even the freshest of systems.
                                          • tbdT
                                            tbd
                                            DLL = Dynamic Linked Library - so they cannot be statically linked (except embedding it in resource and dropping it on execute 😄 )
                                            statically linked libraries (eg. CRT.lib) should add only the used routines to the final executable.
                                            http://plugins.ro
                                            • 6 / 9
