    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 57.1k Views 16 Watching
      jefftrull
      I'm on to the next challenge now... building for the 1.8.7-p334 version my colleagues prefer (better compatibility with certain gems). Unfortunately this one was built with with mingw, and my VS2010 build flow that worked for 1.8.6-p287 (mswin) is not successful here. I have the following results:
      1. build against 1.8.7-p334 built from source with VS2010: compile succeeds, load fails with missing dll msvcrt-ruby18-vc100 (or something like that). If I supply the dll, Sketchup crashes.
      2. build against 1.8.7-p334 one-click install (mingw): compile fails. Lots of warnings about win32.h and missing ruby API functions
      3. hybrid build pointing includes to mswin build of 1.8.7-p334, library from mingw one-click: link error
      I'm under the impression that because dll's use the C API it should be possible to load a VS2010-generated extension into a mingw-built Ruby. Is it a hopeless cause?
      Thanks,
      Jeff
        jefftrull
        Today I made a startling discovery: the plugin I built under VS2010 against the 1.8.6-p287 mswin Ruby will load and run without changes in the 1.8.7-p334 mingw build. So the Ruby version and compiler both mismatch, and yet everything works. I'm dumbfounded but delighted, and my previous question is now moot.
          πŸ‘ πŸ˜„
            @thomthom said:
            Btw, does anyone know how one can make extconf.rb and make/nmake output their files to a given folder? I'd like to make it so that each platform outputs its generated files to separate directories.
            Anyone know how to achieve this?
            Making it so that when I build and compile under Windows everything is placed in a "win32" folder and "osx" when using OSX?
            Or rather, to clarify, I know how to do conditionals - just don't know how to control where the generated files are output.
            • Dan RathbunD
              Dan Rathbun
              and you are compiling from the commandline, not from within the Visual Studio GUI interface, correct ?
              I'm not here much anymore.
                Currently using nmake that comes with MS VS C++.
                And I'm using a extconf.rb with mkfm to generate the makefile.
                  Is it possible to build an Ruby C Extension under Windows that doesn't require additional libraries? When using Visual C++ to build the extensions require the C++ runtime library.
                  • tbdT
                    tbd
                    yes. my old example did that. best is to check the DLL imports section to see what functions it requires
                    http://plugins.ro
                      Ah, the Pelles C project! Is it possible to use to to just compile the C source without creating a project? (just trying to find a solution without creating too many extra project files.)
                      • tbdT
                        tbd
                        the .ppj file is just a collection of commands. you can easily convert it to a .bat file if you dont want to have extra files (remember to create the .def file for the .dll link)
                        http://plugins.ro
                          Do you remember the cause of the C:\ruby\src\ruby-1.8.6-p111\missing.h(71): error #1050: Redefinition of macro 'isinf'. error? And can you explain what your workaround actually do?
                          Trying to set up a project myself so I actually understand this.
                            And why is the macro redefinition just a warning for this guy, but an error in Pelles C?
                            https://github.com/barrie0482/rrdruby_win32_build/wiki
                              hm... there is an msvcrt-ruby18.dll in the SketchUp folder - can I make my Visual Studio C++ project rely on this instead? So when the C Extension loads under SketchUp Ruby the runtime is there - installed by SketchUp. ??
                                isinf is already defined in PellesC libraries so there is no need to include that file again.
                                But I am not including it myself - it's an error that comes from the Ruby missing.h file... :S
                                Building hello_world.obj.
                                Use <stdlib.h> instead of non-standard <malloc.h>
                                C;\ruby\src\ruby-1.8.6-p111\missing.h(71); error #1050; Redefinition of macro 'isinf'.
                                *** Error code; 1 ***
                                Done.
                                  http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version.
                                  When compiling with Pelles C, right? Any way to make VC++'s nmake rely on the bundled SketchUp CRT instead of the VSC++ CRT? (splitting my quest into two projects here...)
                                  • tbdT
                                    tbd
                                    http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version. also you can copy the msvcrt-ruby18.dll in your dev directory to be picked up when debugging outside Sketchup (which I hope you do, otherwise dev time is slooooow)
                                    http://plugins.ro
                                    • tbdT
                                      tbd
                                      that's why you need to have #define HAVE_ISINF 1 in your code, so that Ruby will not double include
                                      compile with the same VC πŸ˜„ or dont link any CRT and use a replacement static lib (there are some minimal libs on the net)
                                      http://plugins.ro
                                        _MSC_VER == 1200 = MVC 6, right? Can you get hold of that version any more?
                                        Here you lost me. "linking"... another concept I need to learn.
                                          That is still greek to me... The only thing I compiled before these Ruby C Extensions where Visual Basic 4 applications... πŸ˜’
                                          • Dan RathbunD
                                            Dan Rathbun
                                            As .. in statically linked, or dynamically linked.
                                            (Hence the DLL and dylib, means Dynamically Linked Library.)
                                            πŸ’­
                                            • 5 / 9
