    [Tutorial] SketchUp Ruby C Extension
    176 Posts 16 Posters 57.1k Views 16 Watching
      http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version.
      When compiling with Pelles C, right? Any way to make VC++'s nmake rely on the bundled SketchUp CRT instead of the VSC++ CRT? (splitting my quest into two projects here...)
      • tbdT
        tbd
        And can you explain what your workaround actually do?
        isinf is already defined in PellesC libraries so there is no need to include that file again.
        http://msdn.microsoft.com/en-us/library/windows/desktop/ms682586(v=vs.85).aspx - the DLL is already loaded by Sketchup so it will use that version. also you can copy the msvcrt-ruby18.dll in your dev directory to be picked up when debugging outside Sketchup (which I hope you do, otherwise dev time is slooooow)
        http://plugins.ro
        • tbdT
          tbd
          @thomthom said:
          But I am not including it myself - it's an error that comes from the Ruby missing.h file... :S
          that's why you need to have #define HAVE_ISINF 1 in your code, so that Ruby will not double include
          compile with the same VC πŸ˜„ or dont link any CRT and use a replacement static lib (there are some minimal libs on the net)
          http://plugins.ro
            _MSC_VER == 1200 = MVC 6, right? Can you get hold of that version any more?
            Here you lost me. "linking"... another concept I need to learn.
              That is still greek to me... The only thing I compiled before these Ruby C Extensions where Visual Basic 4 applications... πŸ˜’
              • Dan RathbunD
                Dan Rathbun
                As .. in statically linked, or dynamically linked.
                (Hence the DLL and dylib, means Dynamically Linked Library.)
                πŸ’­
                I'm not here much anymore.
                • tbdT
                  tbd
                  if you want to have fun - http://www.benshoof.org/blog/minicrt/
                  http://plugins.ro
                    hmm... so I could take my C Extension made with VC++'s nmake and statically link the RT - avoiding having to bundle it or require the users to install any additional RT?
                    • tbdT
                      tbd
                      yes. the dll were created to solve the duplicate code problem but they created another problem - the DLL hell.
                      but for SU extensions having a couple of kB duplicated for the CRT is ok. also it makes the installing easier.
                      http://plugins.ro
                        And from I gathered of the Wiki article, then the DLLs are statically linked they can link just the part of the library required. ??
                        Now I need to figure out how to statically link the CRT. Is it as simple as a compiler flag?
                          -MT instead of -MD seem to be the one...
                          http://stackoverflow.com/questions/8463073/nmake-vc-2010-compile-without-msvcr100-dll-depends
                          http://msdn.microsoft.com/en-us/library/2kzt1wy3%28v=vs.80%29.aspx
                            Changed compiler flag from -MD to -MT
                              On a real world project, Vertex Tools:
                              I can live with that. πŸ˜„ Now it "just works" on even the freshest of systems.
                              • tbdT
                                tbd
                                DLL = Dynamic Linked Library - so they cannot be statically linked (except embedding it in resource and dropping it on execute πŸ˜„ )
                                statically linked libraries (eg. CRT.lib) should add only the used routines to the final executable.
                                http://plugins.ro
                                  designingcrime
                                  I have been working on a plugin to upload and download files to a webserver through http requests. I found this project on the forums a while ago but It wasn't working.
                                  GitHub - danawoodman/google-sketchup-file-downloader: [NOT MAINTAINED] A generic and reusable SketchUp Ruby C extension file downloading utility to be used within SketchUp plugins.
                                  [NOT MAINTAINED] A generic and reusable SketchUp Ruby C extension file downloading utility to be used within SketchUp plugins. - danawoodman/google-sketchup-file-downloader
                                  GitHub (github.com)
                                  Now I have it working and the C Extension compiled fine in Os X.
                                  I have been trying to figure out how to compile it in Windows now so that the plugin can be cross-platform. I started reading this thread but its kind of confusing for me. After following the instructions in this project (which I think are a product of this thread)
                                  404 β€” Bitbucket
                                  (bitbucket.org)
                                  I can compile the example code here with extconf.rb and nmake. However compiling dana's extension is a bit more complicated because it links to libcurl.
                                  there is a line in extconf.rb to check for curllib
                                  Make sure the cURL library is installed.
                                  have_library("curl")
                                  its not
                                  checking for main() in curl.lib... no
                                  creating Makefile
                                  So when using nmake I get this error
                                  fatal error C1083: Cannot open include file: 'curl/types.h': No such file or directory
                                  I downloaded libcurl(curl-7.26.0-devel-mingw64, im on windows 7 and not sure which is the best)
                                  So I can't figure out how to tell nmake to include the path, or where it looks for these files.
                                  Does anyone have experience making ruby c extensions on windows and know how to include 3rd party libraries?
                                  Any help would be appreciated.
                                    I tried to compile Dana's library as well, but since the GiHub project doesn't include the CURL files it failed. And none of the packages I found at the CURL sitecontained the linked files. I asked Dana for which package he used, but it doesn't seem he found it again.
                                    There's another thread around here that talks about Dana's repository.
                                    Need to find out what CURL files are required.
                                    • I
                                      ishboo
                                      Hey y'all,
                                      I have not tried compiling on windows since I own a mac. On Mac libcurl is installed system wide so it is more straightforward setting it up.
                                      One thing that may work is trying to install libcurl using Cygwin and then trying to compile it in Cygwin as well.
                                      I have a coworker who runs windows, so I'll have him an I check it out next week and see what we can find out!
                                      SketchUp plugin marketplace: http://extendsketchup.com/
                                      • Dan RathbunD
                                        Dan Rathbun
                                        This one?
                                        http://forums.sketchucation.com/viewtopic.php?f=180&t=38689&p=415237#p415237
                                          designingcrime
                                          GitHub (github.com)
                                          I had no problem building Dana's library on OS X. Like he said curl ships with OS X so it should be on your system, I think you can check by typing which curl in the Terminal. For some reason if its not there I recommend just downloading from macports and making sure its location is in your System PATH.
                                          Dana's library currently has some inconsistencies about the name of the extension and class its building which creates some problems, in some places it is called file_downloader and in others its called fileDownloader. Change all references to file_downloader to fileDownloader. and run ruby extonf.rb then make.(ignore cmake, because his CMakeList.txt file isn't setup to link libcurl) You will notice a line in extconf.rb
                                          this basically makes sure that when you compile, curl can be found and linked. When running extconf.rb if you see a line like this
                                          checking for curl... yes
                                          this means you will be good to go when you run make
                                          after building you can check and make sure libcurl is linked to your extension by typing in
                                          otool -L fileDownloader.bundle
                                            designingcrime
                                            @ishboo said:
                                            Hey y'all,
                                            Dana, that would be great if you could ask around. As soon as I get this cross compiled, I will clean all the code up, package it nicely and send you a pull request. btw, I also added upload and basic authentication functionality to the utility as well. My head is kinda spinning around with all the different compilers on windows. I'll spend a day looking into Cygwin soon.
                                            • 6 / 9
