    SketchUp 8 M3 - No More Menu Greyout!
    42 Posts 19 Posters 5.7k Views 19 Watching
      danb
      Thom Thom
      Thankyou for pointing me in the right direction, I will send a support note to apple and try and reinstall an older version of Safari
      Dan
      Sketchup Pro 2019/20
      OSX 10.15.3
      Macbook Pro
      • opalO Offline
        opal
        I'm a little late updating .. but now I have no working sketchup on my computer. The installer hunted down and killed all my old versions (back to 5) and when I open the program I have an instant bug splat.
        Does anyone know what the runtime error R6025 - pure virtual function call means and how to fix it?
          The installer only installs or reinstalls/repairs v8, so if you are installing v8M3 you loose v8M2 etc BUT all earlier versions of Sketchup should be unaffected...
          As you are on new[ish] OS presumably you have the earlier versions to reinstall.
          How to fix a runtime error R6025.
          The recommended procedure is:-
          If you have received the message that reads "Runtime error R6025 Pure Virtual Function Call," then the program you are using has been corrupted in some way and will need to be deleted and then re-installed.
          Repeated runtime errors of this nature may indicate a problem with the Registry.
          You could try using the app's REPAIR option and see if that works, before resorting to uninstalling and reinstalling the app.
          Appearing to affect all of the separate Sketchup Registry entries is odd...
          It might be advisable to revert to an earlier OS set, saved when you last installed Windows updates etc... Alternatively do you have any Registry repair tools ?
          • opalO Offline
            opal
            I did go ahead an uninstall M3. I use cCleaner for both the uninstall and registry cleanup.. then go back and do the manual empty folder housekeeping.
            Thankfully, I had the installer for version 8.0.11752 handy, which is installed and running.
            Vertex tools, one of my purchased plugin's is freshly installed but still not showing up so I'll be hunting down version 8.0.3(something) which I am fairly sure is backed up on one of my external drives.
            And I agree.. strange that my previous versions were gone. All but the plug in folders from versions 6 onward had the whole folders emptied. SU5 is in tact.
            Thanks for the reply. πŸ˜„
            • Dan RathbunD Offline
              Dan Rathbun
              Did you originally use cCleaner, to uninstall SU 8.0M2 ??
              Could IT have been the culprit ?? (Meaning, perhaps it "thought" you wanted to remove ALL old versions of SketchUp ??)
              No one else has had any problems, or reported that the v8.0M3 installer/upgrader, touched their versions 7.x, 6.x, etc.
              I'm not here much anymore.
                As it's a newish OS, then also check that there are no 'Compatibility Files' issues... and that for example you are indeed putting files etc into Plugins and not some other 'safe' location that Windows deems best for your own good [without telling you!].
                This will happen if you don't have FULL Security permissions to the Plugins folder [check it under its Properties...] - You need full permissions for Materials, Components and Styles too...
                • opalO Offline
                  opal
                  ok.. um.. I did not uninstall M2 to install M3. I was not using M2 because of the greyed out menu items, I was using the 8.0.3something - and did not uninstall any version prior to installing M3.
                  Due to scary updates in other places over the years, I've become very wary of any updates to programs and tend to move....rename and try to hide working programs from installers - which I had done prior to downloading M3.
                  I had sketchup in a completely different folder (not program files) 3 levels deep, named hidingPVerSU and I still lost them when I installed.
                  I use windows 7.. have been since late in 09 and really don't consider it new anymore since windows 8 is on the horizon. I have gone in and taken ownership of what seems to be every file I have ever accessed on my computer.. given myself admin privs for everything (gawd I miss XP) disabled the UAC and even tried breifly to run everything in XP mode - that was a big fail.
                  Also.. in another place on my hard drive, I have two back up plug in folders. (that probably need updating but they're in tact)
                  I am pretty sure I have my installers for previous versions backed up on an external drive so, when I get a chance to, I'll be searching them for the version that was working before I tried to use M3
                    But v8M3 fixed the 'grayed-out menus', as well as some other issues ???
                    You seem to have got yourself into a terrible tangle... πŸ˜’
                      Dan Rathbun
                      Well, I would say.. on Windows < 6, we could do this with Admin Privs' and no harm. With only User rights, the system would display a popup that warned the user they were moving files/folders from "Programs" and a vague "Some programs may no longer work." (or similar message.)
                      [Even with that, I have lost count of the number of times I have had to "fix" my Aunt's computer, after she has dragged a program folder onto the desktop (which is also a folder.)]
                      Anyway.. I don't think you can fool Windows 6+ by doing that anymore. It is keeping track of where you copy folders from any of the "special folders."
                      I would strongly suggest, you instead manually create and name, a "Restore Point" before running such upgrades / installs.
                      Sometimes an installer will call restore itself (and that's fine, one extra, no problem.) Some installers don't. Your named restore point should not get automatically cleaned up.
                      P.S. - I do not miss XP, because I have not upgraded. (I have to maintain 3 XP and 3 Win7 PCs in my family, and the XPs are so much simplier, and have far less headache.)
                      • opalO Offline
                        opal
                        hehe.. yep.. that's why I went ahead and downloaded it and installed it. I read the release notes and thought.. oh good - update time.
                        shame on me
                        • 3 / 3
