    How to unload a .so file?
    18 Posts 4 Posters 1.1k Views 4 Watching
    • W Offline
      wikii
      I want to unload a win32api.so,then load an other version of win32api.so.
      How can do it.
      wikii
      • Dan RathbunD Offline
        Dan Rathbun
        You want to do this on just YOUR machine, or on other people's machines who have your plugin ?
        I'm not here much anymore.
          Dan Rathbun
          Please explain WHY you think you need to do this ??
          How will you determine what VERSION of Win32API has been loaded ?? (There is no version information within it's C source or it's resulting Ruby class.)
          • W Offline
            wikii
            Just on my own machine.
            • W Offline
              wikii
              I run a plugin,return "Error: #<RuntimeError: Incompatible digest API version>".
              I think maybe a deffirent version of digest API has been loaded.So I want to unload it.
                DO you have the .so version that is appropriate to your Sketchup version ?
                Dan has them set out here http://forums.sketchucation.com/viewtopic.php?p=380121#p380121
                  Dan Rathbun
                  Sounds like your plugin wants to use digest.so
                  • W Offline
                    wikii
                    Yes.
                    Is there a way to unload a loaded *.so file?
                      Dan Rathbun
                      Not really as it's not written in Ruby. It's written in C.
                      The solution is to control the Ruby enviroment you are running, so:
                      Where and what Ruby version is your so files getting loaded from ??
                      What ruby version are you running ??
                      In the Ruby Console type:
                      RUBY_VERSION
                      and
                      RUBY_PATCHLEVEL
                      What platform are you running on?
                      What SketchUp edition, version and MR are you using ??
                      (Your forum user info is not displaying this info. Please go to the forum User Control Panel, and enter this info. It will help us help you better, and the forum's cleanup routine will not flag you as needing to be deleted.)
                        You could do what I did - download the Win32 API from the Win32 Utils project: http://rubyforge.org/projects/win32utils (download the win32-api package), modify it into your own namespace and build your own version.
                        • W Offline
                          wikii
                          RUBY_VERSION
                          and
                          RUBY_PATCHLEVEL
                          Thank you!
                          RUBY_VERSION
                          1.8.6
                          RUBY_PATCHLEVEL
                          287
                          My platform is win7 64bit.Sketchup version is 8.0.14364.
                          And I modified my info in control panel.
                          I need more help about unload a .so file.
                          Thank you!
                            Dan Rathbun
                            Where did you get the .so files that you are trying to load ??
                            What Ruby version / patchlevel did they come from ?
                            • W Offline
                              wikii
                              I found that one plugin uses digest.so from ruby 1.8 , another uses digest.so from ruby 1.86.
                                Dan Rathbun
                                Get the full Ruby & install it
                                and use the !loadpaths script (or something similar,) to be sure that files from the system Ruby libs are loading.
                                http://forums.sketchucation.com/viewtopic.php?t=29412#p257058
                                Remove any standard Ruby .so files from plugin dir.
                                  Dan Rathbun
                                  How are you doing on the so file version situation ??
                                  • W Offline
                                    wikii
                                    I ask the author of the plugin.He told me that plugin use degist.so from 1.8.
                                      Dan Rathbun
                                      Well they need to update the plugin, as SketchUp 8 on Win32 uses Ruby v1.8.6-p287 ...
                                      • W Offline
                                        wikii
                                        Thank you!
                                        He told me he will.
