    How to unload a .so file?
    18 Posts 4 Posters 1.9k Views 4 Watching
    • W
      wikii
      @dan rathbun said:
      Sounds like your plugin wants to use digest.so
      Yes.
      Is there a way to unload a loaded *.so file?
      • Dan RathbunD
        Dan Rathbun
        Not really as it's not written in Ruby. It's written in C.
        The solution is to control the Ruby enviroment you are running, so:
        Where and what Ruby version is your so files getting loaded from ??
        What ruby version are you running ??
        In the Ruby Console type:
        RUBY_VERSION
        and
        RUBY_PATCHLEVEL
        What platform are you running on?
        What SketchUp edition, version and MR are you using ??
        (Your forum user info is not displaying this info. Please go to the forum User Control Panel, and enter this info. It will help us help you better, and the forum's cleanup routine will not flag you as needing to be deleted.)
        I'm not here much anymore.
          You could do what I did - download the Win32 API from the Win32 Utils project: http://rubyforge.org/projects/win32utils (download the win32-api package), modify it into your own namespace and build your own version.
          • W
            wikii
            RUBY_VERSION
            and
            RUBY_PATCHLEVEL
            Thank you!
            RUBY_VERSION
            1.8.6
            RUBY_PATCHLEVEL
            287
            My platform is win7 64bit.Sketchup version is 8.0.14364.
            And I modified my info in control panel.
            I need more help about unload a .so file.
            Thank you!
            • Dan RathbunD
              Dan Rathbun
              Where did you get the .so files that you are trying to load ??
              What Ruby version / patchlevel did they come from ?
              • W
                wikii
                I found that one plugin uses digest.so from ruby 1.8 , another uses digest.so from ruby 1.86.
                • Dan RathbunD
                  Dan Rathbun
                  Get the full Ruby & install it
                  and use the !loadpaths script (or something similar,) to be sure that files from the system Ruby libs are loading.
                  http://forums.sketchucation.com/viewtopic.php?t=29412#p257058
                  Remove any standard Ruby .so files from plugin dir.
                  • Dan RathbunD
                    Dan Rathbun
                    How are you doing on the so file version situation ??
                    • W
                      wikii
                      I ask the author of the plugin.He told me that plugin use degist.so from 1.8.
                      • Dan RathbunD
                        Dan Rathbun
                        Well they need to update the plugin, as SketchUp 8 on Win32 uses Ruby v1.8.6-p287 ...
                        • W
                          wikii
                          Thank you!
                          He told me he will.
