    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 97.1k Views 46 Watching
      snorky
      fluidimporter doesn't work for me!
      (works fine only in a in a previous installation of o.s.)
      i try su7, su8, su8pro trial... 😒
        How doesn't it work?
        It's very frustrating for developers to be told something doesn't work, but then give no clues as to the issue[s]...
        Does it appear on the Import menu list of types?
        Does it open a dialog for options?
        Does it run?
        Does it do anything at all?
        Is the imported object not as expected?
        Does it take a long time to process?
        Does Sketchup crash/bugsplat?
        If you open the Ruby Console before running the importer are there any error messages?
        Can you successfully open this OBJ file in another app like Blender?
        Are the OBJ/MTL files together and any textures in the folder as specified in the MTL?
        You see there are many questions unanswered...
          snorky
          you're right, sorry!
          simply did not appear *. obj on the list of import formats ...
          I do not know what else to explain the problem.
          only now it is on the list
          mystery
          (translated by google)
          • P
            pmolsen
            Just tried to download fluidimporter. Web page comes back with an error Internal Server Error.
              pmolsen
              Worked fine for me just now.
              I'd PM you the zip BUT it's 11Mb...
              • P
                pmolsen
                Worked that time thanks. I tried it for over an hour last night with the same error. Maybe they were doing maintenance.
                  redlerred7
                  I have a problem as well
                  I open a new sketchup 8 window
                  I click File>Import
                  I change "All Supported Image Files" to ".obj files"
                  I select an obj file I exported from sketchup previously
                  I click import
                  The window freezes then closes
                  Bug splat appears
                    πŸ˜•
                    Do you get an options dialog auto-opening before the freeze happens ?
                    If so what settings have you tried/used?
                    Can you try it with a simple 'box' OBJ exported from a SKP.
                    Importing that should work.
                    When you installed the OBJ importer did you have 'admin rights'?
                    Is its .exe in Sketchup's Importers folder ?
                    Have you tried uninstalling it and reinstalling to see if that fixes it ??
                    If you have the Ruby Console open before the import starts are there any error messages ??
                    • G
                      GUNAWAN W
                      just trying to import this model:
                      http://www.flyingarchitecture.com/download/DOT-modo-obj.zip
                      than bugsplat came out πŸ’š
                        The obj file is strangely structured and the mtl lacks good color definitions.
                        I edited the file to ensure all of the 'o[bjects]' become g[roups] with the mtl material immediately afterwards and the matching g[roup]/mat entries before the 'f' blocks was removed.
                        Then it works - units=mm and flip-YZ...
                        stoool.zip
                        • G
                          GUNAWAN W
                          Thanks TIG,will try it as your Sugestion πŸ˜„
                          • iichiversiiI
                            iichiversii
                            Everything ive tried to import is causing bugsplats, πŸ˜’
                            Bring on the Rain...
                              Post a simple OBJ/MTL file set [zipped] that you are having issues with and we can read/test it, to see if it's the file or your setup that needs fixing...
                              • iichiversiiI
                                iichiversii
                                I will have to get back to you on this later Tig, my Internet is down and I'm restricted to my iPhone 😐
                                • W
                                  wingman
                                  Hi sir! I tried using the fluidImporter but I'm having issues regarding the missing materials.. whenever I import an object in Sketchup the materials are always missing.. and sometimes it crashes.. please help on this.. thank you so much in advance!:)
                                  • W
                                    wingman
                                    Here are the images of the imported obj. file and the obj. image...
                                    • W
                                      wingman
                                      imported obj. model
                                        So the geometry is arriving OK ??
                                        You need to do some 'smoothing' as OBJs will always arrive 'faceted'...
                                        Presumably the option to import using textures is set 'on'.
                                        Do you have the OBJ's MTL file?
                                        Do you have the texture images specified in that file ?
                                        Can you PM the whole lot zipped so we can see what the issue is...
                                          Mainline411
                                          Hi, I recently tried this .obj importer but it did not import textures I have tried all the different settings if someone could please work out what the error is even better import it and send me the .skp it would be most appreciated.
                                            To import materials associated with an OBJ file you need the matching MTL file.
                                            These files are readable when opened in a plain-text editor like Notepad.exe.
                                            Near the start of the OBJ code [let's assume it's called Filename.obj] there is a line specifying the MTL - saying something like mtllib Filename.mtl.
                                            This MTL file should be in the same folder as the OBJ file, unless the line of code specifies a subfolder.
                                            The MTL file defines all material e.g. name newmtl WoodColor, color Kd 0.890196 0.882353 0.870588, transparency d 1.000000 etc.
                                            If a specified material uses a texture then the name of its image file is given in the material's MTL code on a line starting with map_Kd.
                                            If there is a folder-path [given as say Textures**/**oak.png] then the image file is expected to be in that subfolder, that is itself in the MTL file's folder; however, if there is no subfolder given in the path then the image file is expected to be in the MTL file's own folder.
                                            The Importer is not clairvoyant - it can only work with the data in the file[s] that you give it.
                                            The most common reason for 'missing materials' is that they are simply missing! πŸ˜’
                                            • 5 / 9
