    [Plugin] Profile Builder Free Edition
    34 Posts 22 Posters 80.9k Views 22 Watching
    • utilerU Offline
      utiler
      Dale sounds like a hardcore user..... 😆
      Just Curious...
      • guanjinG Offline
        guanjin
        Unfortunately, there is no Chinese version,If there is a certain popular!! 😒
        • W Offline
          Whaat
          Seriously, it is one of my most used plugins. 😄 maybe the most.
          I'm still discovering new uses for it. Just recently, I started using it for roofing (ridge caps and hip caps)
          • EarthMoverE Offline
            EarthMover
            Pro user and love it. The bigger my custom created library gets, the faster model creation becomes. 👍
            Content Creator at Skapeup
            • I Offline
              ideas_arte
              The 26 included libraries are a great tool!
              Thank you very much! 😍
              • Bob JamesB Offline
                Bob James
                I've had the pro version for a long time and it is indispensible for my work since I often make models using various size I-beams and channels (plus some "homemade" shapes)
                  Parametric lofting - as it should be. I'm always frustrated when I am handed a model made by someone else where I realise they of course haven't modelled with Profile Builder. The quick change I want to do becomes tedious.
                    There is no possibility to resize (scale) the profile just before the drawing ?
                      Sergio Morera
                      Excellent plugin, very generous of you to provide such a powerful free version. Thank you
                      • brookefoxB Offline
                        brookefox
                        ~ Do not bump ~
                        Thank you very much, Dale. Very kind of you to share the power.
                        And your first video is tasty umami.
                        ~ Brooke
                          jpalm32
                          Liking this PI more & more.
                          Thanks.
                            the.pjt
                            I'm Iranian and we are in a Boycott, and we couldn't buy anything .... thanks a lot for this free version .. thanks a lot.
                            • E Offline
                              etong
                              I've downloaded the plugin, saw the icon, have a dialog box but when I click on the drop down it's empty, click the buttons in the Profile Builder dialog box with no response.
                              Unload I think possible plug-ins that might create some conflicts like the housebuilder and building structure tool but to no avail.
                              Any idea would be welcome.
                                mwm5053
                                house builder an building structures won't interfere with profile builder I use all three. I use the Pro ver so I can't say about the free one but you should have .rb file and a folder titled Profile Builder with a folder in it named library do you? Some libraries come with it and some you can download more on Smustard.
                                2011 iMac
                                SU 2015 Pro, 2017 Make
                                V2 Twilight
                                macOS Sierra 10.12.5
                                  Ben Ritter
                                  Thank you very much.
                                  • W Offline
                                    Whaat
                                    Hello,
                                    I don't believe there are any conflicts with those plugins. I have heard of the issue you are having before. It might be due to your Internet and Javascript settings. Profile Builder uses web dialogs which use javascript.
                                    If you are using Windows, open Internet Explorer and try going to Tools->Internet Options->Advanced->Reset Internet Explorer Settings.
                                    • E Offline
                                      etong
                                      Hello,
                                      Already did what you suggested, still the same problem. Sorry & thanks.
                                        The drop-downs in the dialog are populated from the files available in the tool's folder.
                                        If there are no files/folder then it'll be empty...
                                        As I understand it you should have the following files/folders in your Plugins folder, mimicking the files/folders that arrive in the .zip file...Plugins folder level.PNGPlugins+ProfileBuilder folder level.PNGPlugins+ProfileBuilder+Libraries folder level.PNG If you have additional .plb files these should go into the 'Libraries' subfolder.
                                        • E Offline
                                          etong
                                          As I understand it you should have the following files/folders in your Plugins folder, mimicking the files/folders that arrive in the .zip file...[attachment=2:2oakbtin]<!-- ia2 -->Plugins folder level.PNG<!-- ia2 -->[/attachment:2oakbtin][attachment=1:2oakbtin]<!-- ia1 -->Plugins+ProfileBuilder folder level.PNG<!-- ia1 -->[/attachment:2oakbtin][attachment=0:2oakbtin]<!-- ia0 -->Plugins+ProfileBuilder+Libraries folder level.PNG<!-- ia0 -->[/attachment:2oakbtin] If you have additional .plb files these should go into the 'Libraries' subfolder.
                                          Hi TIG,
                                          All are in its proper order and all accounted for but still the webdialog appears empty.
                                          Sigh!
                                            Have you checked the security permissions for these folders/files? ...
                                            And that they are actually what they say they are?
                                            Windows can put things into 'Compatibility Files' folders without telling you, but display them as if they are really where you intended...
                                            This can happen if you don't have FULL security permissions to the Plugins folder and its contents etc...
                                            Otherwise I am at a loss... any others want to chip in ??? 😕
