    Mouse binding
    19 Posts 7 Posters 2.0k Views 7 Watching
      snead hearn
      Oh, dear. Look here, Minnie.
      I return here after a week and all I find are a few human droppings.
      Oh, dear. Oh,dear.
      • jeff hammondJ
        what about your mouse driver?
        some of them (Logitech for example) allow for customization that way.
        • KrisidiousK
          Krisidious
          Oh, dear. Oh,dear.
          By: Kristoff Rand
            Roger
            🤣 Clearly Snead is in the spirit of the moment.
            http://www.azcreative.com
              jaceguay
              I recommend Autohotkey for this type of customization, If you tell me what you are you trying to achieve I“ll help you make a script.
                snead hearn
                Jacequay-
                I investigated Autohotkey, but did not go further because it wasn't clear
                if it would allow changing the mouse inputs for only Sketchup and not for
                everything on my computer.
                For all the other 3d software that I use, the following mapping has become
                ingrained in muscle memory:
                Orbit = Alt + Lmb
                Pan = Mmb
                Zoom = Scroll wheel
                If Orbit and Pan could be reset for Sketchup only, I wouldn't be tripping over
                them all the time.
                Your help is most welcome.
                Snead
                  jaceguay
                  Hi, the script follows, it changes the orbit and pan as you describe, to use it just install autohotkey, after you run it for the first time it will create a template script on your documents folder, you can open it with notepad delete what“s there and paste this.
                  The IfWinActive, SketchUp ensure that it will only be active in the sketchup window.
                  #SingleInstance force
                  #NoEnv
                  #Persistent
                  #ErrorStdOut
                  SetTitleMatchMode 2
                  #IfWinActive, SketchUp
                  *MButton;;
                  SendEvent {Shift Down}{MButton down}
                  KeyWait MButton
                  SendEvent {Shift Up}{MButton up}
                  return
                  *!LButton;;
                  SendEvent {MButton down}
                  KeyWait LButton
                  SendEvent {MButton up}
                  return
                    snead hearn
                    Thank you for your response and guidance, jaceguay.
                    I installed the script as you indicated. Upon opening Sketchup it worked beautifully.
                    All was well until I closed Sketchup and turned off the computer. Upon reopening the program,
                    Sketchup had reverted to its default Orbit and Pan.
                    After going back through the installation steps and checking the AutoHotkey help files,
                    and making no progress in finding an answer, I tried Start > AutoHotkey > Open. Nothing
                    visible happened. However, when I opened Sketchup again the script was working. It appears
                    that shutting down and restarting the computer is the problem.
                    This is beyond my abilities to solve. Do you have any ideas or suggestions?
                      jaceguay
                      Autohotkey must be running to make the modification work, the installation don“t make it start automatically with windows, so you can start it yourself every time you want to use sketchup or to make it easier you should put autohotkey as a start up program. After you start Autohotkey to ensure it its running see if you can find a green "H" beside the clock on the taksbar.
                        snead hearn
                        jacequay,
                        Again, thank you. It is now working as I wished.
                        Jeff Hammond,
                        I had previously checked Logitech drivers. However, they do not allow modification of
                        the primary mouse buttons.
                        Thanks to all.
                        Snead
                        With your input, this post could be even better šŸ’—
