    Mouse binding
    19 Posts 7 Posters 2.0k Views 7 Watching
      Roger
      Kris, we have the identical rodent minus the bondage. We had a mouse in the house and in addition to traps we figured the large stuffed rodent might be intimidating.
      http://www.azcreative.com
      • GaieusG
        Oh, come on guys. Here is a member posting the first time an you make fun of him.
        @snead: I do not think that "mapping" (as I would call it) mouse commands is possible in SU. They are all hard coded. You have probably discovered the shortcuts panel but (of course), there's nothing there. Unfortunately, what I know of the ruby API (about - nothing much actually), it does not allow such modifications either.
          Roger
          Snead, I apologize. Gaius, I admit that I made a Mickey Mouse comment.
          • KrisidiousK
            Krisidious
            oh sorry Snead... didn't realize this was your first post.
            By: Kristoff Rand
            • GaieusG
              Okay guys (and the same time I have to admit that I also had some giggle moments) 😉
                snead hearn
                Oh, dear. Look here, Minnie.
                I return here after a week and all I find are a few human droppings.
                Oh, dear. Oh,dear.
                • jeff hammondJ
                  what about your mouse driver?
                  some of them (Logitech for example) allow for customization that way.
                  • KrisidiousK
                    Krisidious
                    Oh, dear. Oh,dear.
                    By: Kristoff Rand
                      Roger
                      🤣 Clearly Snead is in the spirit of the moment.
                        jaceguay
                        I recommend Autohotkey for this type of customization, If you tell me what you are you trying to achieve I´ll help you make a script.
                          snead hearn
                          Jacequay-
                          I investigated Autohotkey, but did not go further because it wasn't clear
                          if it would allow changing the mouse inputs for only Sketchup and not for
                          everything on my computer.
                          For all the other 3d software that I use, the following mapping has become
                          ingrained in muscle memory:
                          Orbit = Alt + Lmb
                          Pan = Mmb
                          Zoom = Scroll wheel
                          If Orbit and Pan could be reset for Sketchup only, I wouldn't be tripping over
                          them all the time.
                          Your help is most welcome.
                          Snead
                            jaceguay
                            Hi, the script follows, it changes the orbit and pan as you describe, to use it just install autohotkey, after you run it for the first time it will create a template script on your documents folder, you can open it with notepad delete what´s there and paste this.
                            The IfWinActive, SketchUp ensure that it will only be active in the sketchup window.
                            #SingleInstance force
                            #NoEnv
                            #Persistent
                            #ErrorStdOut
                            SetTitleMatchMode 2
                            #IfWinActive, SketchUp
                            *MButton;;
                            SendEvent {Shift Down}{MButton down}
                            KeyWait MButton
                            SendEvent {Shift Up}{MButton up}
                            return
                            *!LButton;;
                            SendEvent {MButton down}
                            KeyWait LButton
                            SendEvent {MButton up}
                            return
                              snead hearn
                              Thank you for your response and guidance, jaceguay.
                              I installed the script as you indicated. Upon opening Sketchup it worked beautifully.
                              All was well until I closed Sketchup and turned off the computer. Upon reopening the program,
                              Sketchup had reverted to its default Orbit and Pan.
                              After going back through the installation steps and checking the AutoHotkey help files,
                              and making no progress in finding an answer, I tried Start > AutoHotkey > Open. Nothing
                              visible happened. However, when I opened Sketchup again the script was working. It appears
                              that shutting down and restarting the computer is the problem.
                              This is beyond my abilities to solve. Do you have any ideas or suggestions?
                                jaceguay
                                Autohotkey must be running to make the modification work, the installation don´t make it start automatically with windows, so you can start it yourself every time you want to use sketchup or to make it easier you should put autohotkey as a start up program. After you start Autohotkey to ensure it its running see if you can find a green "H" beside the clock on the taksbar.
                                  snead hearn
                                  jacequay,
                                  Again, thank you. It is now working as I wished.
                                  Jeff Hammond,
                                  I had previously checked Logitech drivers. However, they do not allow modification of
                                  the primary mouse buttons.
                                  Thanks to all.
                                  Snead
