    Hello... and .stl files...
    8 Posts 4 Posters 1.1k Views 4 Watching
      AdamG
      Hi All,
      Am new here but thought I'd say hi and also start to scratch your collective brains.
      Am a sculptor by trade and am now moving into digital sculpting... Have fallen in love with SketchUp and going pro latter this week. However I've hit my first major brick wall... how on earth do I save my .SKP files as .STL files so I can send them to be 3d printed?
      Have downloaded CADspan and the Guitar list plugin. Can create .DXF files no problem but .STL remains elusive. 😠 😠 😠
      Thanks for any pointers etc, and hope to be able to add to the community.
      Cheers
      Adam
      • ely862meE Offline
        ely862me
        Hi there !
        See if this helps you ! http://forums.sketchucation.com/viewtopic.php?t=24515
        Cheers !
        Elisei (sketchupper)
        Come and See EliseiDesign
          d12dozr
          @adamg said:
          ... the Guitar list plugin. Can create .DXF files no problem but .STL remains elusive.
          When exporting STL with the Guitar list plugin, type the filename then actually type ".stl" on the end. For some reason that plugin doesn't append the filetype.
          http://goo.gl/f7ooYh
            AdamG
            Cheers guys, fingers crossed it will work.
            πŸ‘
              AdamG
              hmmm... still no .stl file but instead saved as a certificate trust list.. any pointers? I'm hoping that its me overlooking a simple procedure... 😐
                d12dozr
                Did you try typing .stl on the end? You can also rename the file after exporting it.
                ...so "mymodel" becomes "mymodel.stl"
                I was confused by the "certificate trust list" thing too, until I figured out I could rename the file.
                Hope that helps. If not, I suggest contacting the plugin author.
                • TIGT Online
                  The STL file extension is presumably used by another app as well as the 3d-modeling file-type...
                  http://answers.yahoo.com/question/index?qid=20060729214536AAfI1Dl
                  This sometimes happens where two apps use the same extension πŸ˜’
                  The link explains how to swap it over...
                    AdamG
                    Thanks again guys, think its worked
                    It's just a simple chess piece, being printed hopefully tomorrow....
