    Google Drive is live
    59 Posts 19 Posters 1.5k Views 19 Watching
    • jeff hammondJ Offline
      fwiw, 'drive' still wasn't showing up in the google menu bar so i went to:
      https://drive.google.com/start
      (where it previously said my drive wasn't ready yet)
      and was able to get it going
        @edson said:
        one thing I immediately noticed is you cannot get links for other people to download your files. unless this is done in some other way through google docs but this would be much more complicated than in other similar services.
        it's the same (well, similar) as dropbox.. right click on the file then go 'share…'
        go to 'share..' again then change who has access..
        you can probably link to photos etc as well.. test to follow..
        https://lh3.googleusercontent.com/dIVr2cgicKwHmEXc6lnVGkZ7lvtzAfPGg-BojUa78C5fhaRHmpuqi94t5Y3SiUJjNj8TmhMj5HY
        [EDIT] yep.. works 😉
        and maybe there's a way to create a 'Public' folder ala dropbox so you don't have to change individual access settings..?
        (edit2)--- looking from a phone now and that picture isnt showing up. anyone else seeing an embedded image above?
          d12dozr
          Not showing for me. If if Right click -> view Image, I get a 403 Forbidden error
          http://goo.gl/f7ooYh
            hmm. ok. thanks
            I kind of need that ability. I'll try some other stuff later to see if it's possible.
            (unless someone already knows how ?)
              d12dozr
              Test:
              https://lh3.googleusercontent.com/xrDjDp-bjK6oymDyG-4t-WlV8zZrrnO6y27wRvRgae1OvGvmjSSXDeVoJlDL22PDrBgA866-pUM
                d12dozr
                It looks like it worked for me right up there(tested from a different browser) - In Google Drive, after clicking the Share button, I just set the Sharing Settings to "Anyone with the link". You could make it "Public" as well.
                Edit: wait, just tested from a 3rd browser and now it doesn't show...can you confirm or not?
                  yeah. not showing up for me.
                  the links are shareable though. I tried that earlier.
                    d12dozr
                    Ok, testing with setting at "Public"
                    https://lh6.googleusercontent.com/3C6Qq_kUwXBQast1ij7Ri-XzXe_pf6XsqQA7tRPzOstC7XU5PMN0_ELBmW4IHpX746ZFta2SMek
                    Edit, yeah, what you said. Links work, but not embedded images.
                      Not even links. If I try to display the image in a new tab, it say 403 (forbidden)
                        d12dozr
                        Here's a link that should work Gai: https://docs.google.com/open?id=0B99bfxSe2Z4HRjM0VUZzTWVIQ0k
                        I didn't have any links above, but I tested using another browser.
                          This is what I get:
                          https://lh3.googleusercontent.com/gPXi8sMSpHnE5uVISZm8hsWZpidJ5m3ORCA4d7hW9hfJODAh1uM7gJ17jKnNsWcNpKR8f0kCTR8
                            d12dozr
                            And this is what I see:
                              meh.. I think I'll stick with Dropbox for now..
                              ..and hope iCloud picks up some more features soon.
                              (though I doubt it.. mobileMe, iCloud's precursor, had some of the functions I need but they were stripped away with iCloud)
                              • JpacJ Offline
                                Jpac
                                I took Paul Russam's write up on Dropbox with links and put my Plugins folder in the cloud:
                                http://forums.sketchucation.com/viewtopic.php?f=179&t=44852
                                I compared Google Drive, Microsoft SkyDrive, and Dropbox.
                                They all executed at the same speed (Google Drive might be slightly faster).
                                So moving your Plugins to the cloud to better manage them is worth doing!
                                Here's my blog about this and it gives the steps needed to use Link Shell Extensions (for Windows only sorry to say):
                                http://sketchupland.posterous.com/sketchup-plugins-in-the-cloud
                                http://sketchup4sitedesign.wordpress.com/
                                  @john
                                  fwiw, andrea.bianco was the first to put up dropbox/sketchup syncing instruction at scf (that i'm aware of)
                                  http://forums.sketchucation.com/viewtopic.php?f=15&t=40866
                                  • 3 / 3
