    One-liners
    22 Posts 6 Posters 853 Views 6 Watching
    • N Offline
      noelwarr
      Here is a chance to show off your ruby skills. One line of code that does something cool that you can copy and paste into the console. I'll keep editing this post adding your contributions so you can find the one-liners easily. The first is mine (very simple I know).
      Reconstruct all possible faces from selected entities
      Sketchup::active_model.selection.each{|ent| ent.find_faces if ent.is_a?(Sketchup::Edge)}
      Run this befor printing
      (av = Sketchup.active_model.active_view).camera.perspective = false; av.zoom_extents.zoom(1.052)
      And here is a challenge: ArcCurves get lost on solid operations. Can you recreate them in one line of ruby? (Hint: If 3 or more edges are on the same plane and the angle between each is the same and less than or equal to 15, we can assume it is part of a lost ArcCurve)
      • Dan RathbunD Offline
        Dan Rathbun
        The each iterator returns the receiver (upon which it acts,) not the result of the block.
        Try using one of the iterators from the Enumerable mixin module (which is mixed into most of the API collection classes.)
        I might as well give it to you:
        find_faces_of_selected_entities = Sketchup.active_model.selection.find_all {|ent| ent.is_a?(Sketchup::Face)}
        I'm not here much anymore.
          Dan Rathbun
          Wouldn't it be cool if there was a Chrome plugin, where you could hilite a Ruby statement on SCF, right-click the mouse, and choose "Send to SketchUp Console" ??
          • N Offline
            noelwarr
            I was unaware of the find_all method. You live and learn. The one-liner you propose, however, does nothing. It would be useful in the context of more code. I think the problem is the variable name I chose. It is misleading. Here is the original code I posted
            find_faces_of_selected_entities = Sketchup::active_model.selection.each{|ent| ent.find_faces if ent.is_a?(Sketchup::Edge)}
            I say find_faces_of_selected_entities because the Edge class has the find_faces() method. I think both should be renamed to reconstruct_faces or something. In the hope everything is more clear we'll get rid of the variable alltogether. I'm changing my first post to...
            #Reconstruct all possible faces from selection
            Try it out. Draw something, delete a few faces, select everything and run the one-liner.
              Dan Rathbun
              YOUR CODE DOES NOT WORK ! .. as I had said.
              It returns nil
              • N Offline
                noelwarr
                What it returns is irrelevant. It's what it does that matters, Dan. Please see attatched video for proof (Sorry its in wmv). There was a moment of fear when the code did nothing. Then I realised I had nothing selected ๐Ÿ˜„
                I know it is bothersome when people post code that doesn't work. I'm sory if I didn't explain myself correctly giving the impression that that was the case. It is also, however bothersome when people say
                without considering the possibility that it might.
                Rest assured I shall be checking the oneliners people post before I include it in my first post.
                oneliner.wmv
                  It does work, in that it adds faces to selected edges.
                  For me it works, then returns the selection, not the new faces or nil.
                  I think the initial confusion was that the code had something like "add_faces_to_selected_lines=..." to show what it did, and of course add_faces_to_selected_lines is set to be the selection, I assume this was used because of the arbitrary rule that you can't use a ';' - which makes it impossible to do a one-liner with its intent shown unless you add '#' and then the description at the end of the code line...
                  • N Offline
                    noelwarr
                    You got it TIG. Could you suggest a way to rephrase the whole "challenge" so it is readily apparent?
                      Dan Rathbun
                      Yes I was confused by the original wording you chose.
                      • daikuD Offline
                        daiku
                        OBFUSCATORS!
                        Your goal should be to write the most readable code possible. This is the opposite.
                        Clark Bremer
                        http://www.northernlightstimberframing.com
                        • N Offline
                          noelwarr
                          ๅคงๅทฅใงใ™ใ‹ใ€‚ใ™ใ”ใ„ใ€‚ไฝ•ๅนดๅ‰ๆ—ฅๆœฌใซไฝใ‚“ใ ใ‘ใฉใ€‚ๅคง้˜ชใซใ€‚ใใ‚Œใซใ€็งใ‚‚ๅคงๅทฅใงใ™ใ‚ˆใ€‚้ข็™ฝใ„ใ€ใชใใ€‚
                          Anyhow, I'm not advocating for this type of code, though I think it's cool that ruby allows for it. All I wanted was a list of cool lines that one might copy and paste into the console to do something useful. Instead it would seem I've started a flame war or something ๐Ÿ˜ฎ
                          • daikuD Offline
                            daiku
                            Sorry, but I don't speak a lick of Japanese. I can tell from the first two characters that this was addressed to me, but the rest is lost on me. As a professional timber framer, the Daiku are my heroes. We had a group come to one of our conferences, and the level of skill and craftsmanship was amazing.
                            And of course I was only trying to be clever with my first post. Nothing personal ๐Ÿ˜„
                            Clark Bremer
                            • N Offline
                              noelwarr
                              No offence was taken! ๐Ÿ˜› The japanese just says I'm a carpenter too and lived (a short period of time) in Osaka a few years back. I was also not left unmoved by Japanese craftmanship when it comes to woodworking. We even ended up selling one of their products a few years back, here in Europe. http://mitaka.eu/
                              It's still the traditional side that gets to the heart ๐Ÿ˜Ž
                                Why no semi-colons? Seems that we're doing one-statements instead of one-liners then.
                                • jeff hammondJ Offline
                                  @thomthom said:
                                  Why no semi-colons?
                                  meh..
                                  view = Sketchup.active_model.active_view ; view = view.zoom 1.052
                                  parallel projection -> zoom extents -> use the code for true zoom extentsโ€ฆ
                                  i use it sometimes for printing.
                                  (also part of an applescript i use for easy printing to scale from sketchup)
                                  • N Offline
                                    noelwarr
                                    Why not...
                                    Sketchup.active_model.active_view.zoom(1.052)
                                    Or to include the zoom extents...
                                    Sketchup.active_model.active_view.zoom_extents.zoom(1.052)
                                    Don't know how to activate the parallel projection though. Anyone?
                                      Dan Rathbun
                                      Activate Parallel Projection for the current View's Camera:
                                      Sketchup.active_model.active_view.camera.perspective = false
                                        view.zoom 1.052
                                        Where does this magic number come from?
                                          Dan Rathbun
                                          @thomthom said:
                                          view.zoom 1.052
                                          .. and it seems to work in Parallel Projection mode, but not in Perspective mode.
                                            @noelwarr said:
                                            Why not...
                                            Because I don't know ruby ๐Ÿ˜‰
                                            I just found something that worked for what I needed.
                                            but your version doesn't use a semicolon so I'll make that my thread entry ๐Ÿ˜„
