    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      You welcome. But now you are not allowed to install another plugin until you can master this one. Three days from now exam. ๐Ÿ˜‰
      • N Offline
        nasos.slab
        ๐Ÿ˜Ž u can bet on that !
          Demetrous
          Great plugin!
          Thank you, Chris!!!
          • Z Offline
            zunkian
            I'm getting bug splat with SU 8 in Win 7 each time I press enter after picking the object, then the straight line, then the curved line. What's causing this and how do I resolve the problem?
            Any help would be appreciated.
            zunkian
              Please post a simple example SKP.
              Are you absolutely sure you have installed the required files properly as set out in the download page [including progressbar.rb] ??
              Try it with the Window > Ruby Console to see if there are any error messages...
              The process is this:-
              Place the Group.
              Add/locate/size a Line parallel to the X/red-axis
              Add/locate/size a Curve to bend around.
              Select the Group.
              Run the Tool.
              Pick the Line.
              Pick the Curve.
              A bent version [as a component] is added to the SKP...
              • Z Offline
                zunkian
                Hi Tig,
                I did what you suggest applying the ruby while the ruby console is open.
                It started with an error message then suddenly the script runs down the
                console until it completed it's task! The shape bender worked with no
                bug splat!
                Thanks!!!
                zunkian
                  @zunkian said:
                  Hi Tig,
                  bug splat!
                  Thanks!!!
                  zunkian
                  What was this 'message' ?
                  Perhaps about 'make_unique' being 'deprecated' ?
                  It's kind to share this kind of thing, so that we can help others with related issues...
                    GK65
                    I had the same problem. The plugin works great when I bend a simple shape, but when I try to bend a more complex shape I get the following error code:
                    Error: #<NoMethodError: undefined method all_connected' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:364:in curve_picker'
                    8/Plugins/clf_shape_bender/clf_shape_bender.rb:242:in `onLButtonUp'
                    The error comes up after I select the straight line. Then when I select the curved line it goes to 15% then splat!
                    I love the plugin, hope I can get it working.
                    GK
                    • W Offline
                      Wlado87
                      I have a problem with Shape Bender. The object is incomplete.
                      see:
                      https://lh3.googleusercontent.com/Ktj4QcHhGKOlIq-17yFlo72xUWgv21Xw3LZVye8uKB7kSAU2tsbN9GncEcf1ZD7FE-trkfoGhHM
                      https://lh3.googleusercontent.com/7-_KTFhou6ZBcFkIL9IrBzHLThw8V2Qq4SjItYizF-Ykbq8gf7-KPSnTT4ipdbQCLmd-x_OsxOc
                      What is wrong.
                      skp is in attachment.
                      Untitled.skp
                        What is wrong is that your original is only 1/4 of a centimeter long. Too small for SketchUp. It works perfectly if you scale it up to a reasonable size, first.
                        shape bend.skp
                        • W Offline
                          Wlado87
                          I had the same problem when I was doing with the larger size. But the problem was gone when i removed the SketchyPhysics plugin.
                          I have new problem (in picture). The green grid is out of way.
                          https://lh6.googleusercontent.com/af0n09oRwWEsOVhBeh-gLb30N1Lxvu2AZ7f1BuwpSW_8Dj5Bifren5mOLYiW1XWUUgc22DE5BNA
                          Thanks for first answer.
                          Struna1.skp
                            I don't know what you mean by "out of way" but it seems to me that you would benefit from learning more about the basics of using SketchUp before you get to trying stuff like this. What you're asking SketchUp to do is create a huge number of edges and faces which is going to cause it to bog down at best. You could create this shape much more easily if you made only a single revolution of the helix and copied it enough times to make up the length you need.
                            And work at a larger scale to give SketchUp half a chance to do what you want.
                              Shirin2u
                              I have a problem with using this plugin. Im new to sketchup, I downloaded the file and the processor but I dont know how to make it work lol anyone can help me here please?
                              when I click on the file its like I cant open or install anything.
                              • BurkhardB Offline
                                Burkhard
                                There are some threads here, which explains how to install Plugins. Here is one:
                                http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                [http://www.ia-plus.de(http://www.ia-plus.de)]
                                • W Offline
                                  winnersky
                                  thank you
                                  • H Offline
                                    hlferrell
                                    This tool looks incredible! I haven't gotten it to work yet, though. I have created a ramp and an arc and a line that stretches the length of the ramp - the line is on the red axis as the instructions indicate. I select the component (the ramp), then I select the shape bender tool and then try to select the single line. It doesn't seem to recognize the line - or anything once I've selected the shape bender tool.
                                    Any advice would be greatly appreciated. Thanks!!
                                      There are a number of things that it could be. Could you post at least a screen shot of the setup?
                                        Also try doing it it with the Ruby Console open and post us any error messages - this might help us see what's wrong.
                                        The picked line and then picked curve can't touch each other, or any other 'raw' geometry.
                                        We can but hope that you have correctly extracted and then installed the tool's subfolder with all of its cursor/toolbar image files etc intact, and that you have also installed 'progressbar.rb' from Smustard.com, all as advised on the download tool's page.
                                        These are the two "most popular" screw-ups ๐Ÿ˜ฎ
                                          cizqa
                                          Hello guys, please help me ๐Ÿ˜„
                                          This is my first time using this plugin and I am having error
                                          ERROR: skpHelperClasses.rb:updateSkpMaterial, curMat is nil
                                          It shows continuously after I click on the Shape Bender icon, it stops when I click on the red-axis line, and it starts to show again after I click the curve. I get to the screenshot I attached, but when I click enter to finalize the bending --> bugsplat!
                                          Anybody knows what's wrong? Thank you very much.
                                          Siska
                                            This is a V-ray related error and sometimes appears in other tools when it's not working properly.
                                            http://forums.sketchucation.com/viewtopic.php?p=327671#p327671
                                            If you disable V-ray and restart Sketchup does the error stop ?
                                            Thomthom also has a script that disables V-ray's load until you need it, which also speeds up startups...
                                            Also check on the latest V-ray version etc as he advises in the link above...
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 63
                                            • 64
                                            • 55 / 64
