    Saving your Vray progress for later region rendering
    renderpluginsextensions
    3 Posts 2 Posters 2.1k Views 2 Watching
    • N
      n3v
      Hi guys
      I plan on doing a series of renders over the next few days, they will all be taken from exactly the same view, but likely that a series of small areas/materials will be changed, which I'd obviously correct with region renders. However when switching off your machine or closing sketchup you loose the image generated in the frame buffer so ultimately loose the option to region render parts of the image not to mention the amount of wasted time. Is there a way to save this base image and get vray to region render parts over it at a later date? at the mo I'm using an irradiance map followed by a light cache
      thanks
      Sketchup 7 and vray 1.48.01
        I think the latest 1.49.01 let you load an image into the VCB...
        • N
          n3v
          Hi Thom
          Can you elaborate a little more please?
