    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 26.4k Views 18 Watching
    • yad2000Y Offline
      yad2000
      @driven said:
      I had to change all the Sketchup:: require'' to require '' to return true and see the Toolbar.
      If I comment out all 'Iconv' references in all the files, Webkit on mac appears to handle the Cyrillic encoding without any issues.
      Is
      <script type="text/javascript" src="js/documets_pack.js"></script>
      still needed? I get an error.
      If I change ini.rb to "Lang=en", on start I get a message box Did not load RB script&#058; /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb
      if I start with Lang=ru and then change ini.rb and reload, I get
      Error: #<TypeError: /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb:81:inadd_item': can't convert nil into String>`
      I can't get much further without English, but will keep trying.
      Work on the multi-language version is started, the news wrote about this on your site. Much more needs to be done (not without some help users of course).
      The plugin is provided as is and use it to recommend your own risk.
      @dan rathbun said:
      OMG! WHAT A PIECE OF CRAP......
      Please calm down!
      I am not a programmer proffessionalny Ruby, do what learned.
      I do not claim to uniqueness and correctness of their decisions. Your comment will take into consideration and try to make changes with the next version.
      As the saying goes do not like do not eat, and you should not call all the crap.
      CoolPipe Plugin
      • yad2000Y Offline
        yad2000
        #-v1.2.1
        Multi-project choice of language in the process of working with the plugin
        Calculation of the mass-removal (steel), raschityvatesya of geometrical parameters (may not fit with factory products)
        #-The structure of the code changes: there is no change in the standard classes, all of the code integrated into classes and modules
        #-correction made for loading iconv.so: The MAC does not load, only on Windows
        edit-elements located outside the Observer in the allocation of a separate command button
        #-fixed principle of sorting elements of the standard specification. sort (to avoid memory leaks in the process of counting and hangs SketchUP)
        CoolPipe Plugin
          jorge2011
          thanks for the update. But still generates the same error, when using the tool "tube":
          Error: #<ArgumentError: Not enough edges - at least 3 required>
          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in cp_create_pipe_geometry'
          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:110:in `onLButtonDown'
          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:247
          you can fix it?
          I use:
          windows xp in Spanish
          sketchup 8 pro in Spanish
          • kenK Offline
            ken
            I receive the following error code after installing.
            Thanks you in advance for your help.
            Ken
              jorge2011
              Ken
              You must copy the file "iconv.so" in the folder:
              windows/system32
              • kenK Offline
                ken
                Jorge
                Will thanks for the advice, however I still have the same error code.
                Ken
                • guanjinG Offline
                  guanjin
                  Site not open
                  • yad2000Y Offline
                    yad2000
                    you can fix it?
                    I use:
                    hmm ...
                    very strange ...
                    I was not able to repeat that mistake, I can recommend:
                    Line number 569 is:
                    face = entities.add_face circle
                    Try replacing the line number 557:
                    circle = entities.add_circle pt1, vecbegin, radius, numsegs
                    on the line
                    circle = entities.add_circle pt1, vecbegin, radius, 24
                    or if not, then the line
                    language is not involved, but rather a problem of API in your version of SketchUP, although the design:
                    works with the version of SketchUp 6.0+, can you have an earlier version, not 8.0 PRO? in a previous version of the plug CoolPipe 1.2.0 you have the same problem was, nobody else it is not repeated
                    CoolPipe Plugin
                      jorge2011
                      This solution does not work.
                      the list of error:
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570:in cp_create_pipe_geometry'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:110:in onLButtonDown' Error: #<NoMethodError: undefined method bounds' for nil:NilClass>
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:90:in creategeometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:67:in onLButtonDown'
                      Error: #<NoMethodError: undefined method bounds' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:90:in creategeometry'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:68:in onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:90 Error: #<NoMethodError: undefined method bounds' for nil:NilClass>
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in creategeometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:67:in onLButtonDown'
                      Error: #<NoMethodError: undefined method bounds' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in creategeometry'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:67:in onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90 Objeto elegido CoolPipe = Error: #<NoMethodError: undefined method []' for nil:NilClass>
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:594:in getparams_frompipe' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:327:in reset'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:296:in initialize' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:3070:in new'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:3070:in cp_edit_coolpipe_elements' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:21:in cp_add_toolbar_button'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in call' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90 Error: #<NoMethodError: undefined method layer' for nil:NilClass>
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:594 Error: #<NoMethodError: undefined method layer' for nil:NilClass>
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67 Error: #<NoMethodError: undefined method length' for nil:NilClass>
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2819:in cp_get_length_tube' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2931:in generate_CoolPipe_specification'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2925:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2925:in generate_CoolPipe_specification'
                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:25:in cp_add_toolbar_button' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in call'
                      • Dan RathbunD Offline
                        Dan Rathbun
                        @yad2000 said:
                        Line number 569 is:
                        try:
                        face = entities.add_face( circle.edges )
                        I'm not here much anymore.
                        • yad2000Y Offline
                          yad2000
                          That's right, because you're not going to work. This plugin is targeted to the appropriate users. You have added a new document and a new tube without any parameters, of course anything you do will not work. The parameters necessary to specify everything: nominal diameter, outside diameter, wall thickness, the name of the pipeline, etc. All that is required.
                          So that promote your cause, or assist in the development or discourage new users
                          CoolPipe Plugin
                          • yad2000Y Offline
                            yad2000
                            Please bring a list of documents for which you want to add elements. Now used only 2 Russian document on the piping. If you write a number of documents that you use and you can download them somewhere, I'll add them to the database to avoid similar mistakes.
                            CoolPipe Plugin
                              tony bombata
                              Ken
                              windows/system32
                              i use x64 windows and i had the same problem
                              copied iconv.so and iconv.dll to win2, wow64, sketchup plugins and coolpipe folders
                              don't know which worked out but it's working
                                Dan Rathbun
                                Well which one of those paths are in the $LOAD_PATH array ??
                                • guanjinG Offline
                                  guanjin
                                  I can not open the page, to download, why not posted on the website
                                  • yad2000Y Offline
                                    yad2000
                                    Coolpipe.ru site - located in the ucoz.com - if none of the sites of ucoz you can not read - then the problem is with your provider.
                                    CoolPipe Plugin
                                    • guanjinG Offline
                                      guanjin
                                      @yad2000 said:
                                      @irwanwr said:
                                      if the plugin will be available in English version and shared here too.
                                      if it is true.
                                      this is true, but it will probably not soon. Will take some time to create a fully functional version of the native language, only then do the translation. It is possible I will ask for help - if you do not mind
                                      Finally downloaded, loaded error
                                      • yad2000Y Offline
                                        yad2000
                                        @guanjin said:
                                        @yad2000 said:
                                        if it is true.
                                        [attachment=0:15v5ur39]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:15v5ur39]
                                        in the file that you changed - Error!
                                        you must:
                                        "沿线 管道 目录 列表,
                                        replaced by
                                        "沿线 管道 目录 列表",
                                        should work
                                        CoolPipe Plugin
                                        • guanjinG Offline
                                          guanjin
                                          Successfully translated into Chinese, but has not been used successfully, the of plumbing tools?
                                          • yad2000Y Offline
                                            yad2000
                                            Normative documents only Russian. To broaden the base of the elements - I need to know what documents you use. They are very much, all I add one can not afford
                                            CoolPipe Plugin
                                            • 2 / 4
