    Invert model - show 'negative' space?
    8 Posts 4 Posters 2.9k Views 4 Watching
    • N Offline
      nickdk
      Good evening πŸ˜„
      Is there a plug-in that will convert a model to its the negative space? (see image) πŸ˜›
      • jeff hammondJ Offline
        @nickdk said:
        Good evening πŸ˜„
        you can use solid tools for that.
        • N Offline
          nickdk
          I will investigate these Solid tools πŸ˜„
          thanks
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            Solid tools are available only in SU 8 Pro.
            See this SU file for two ideas (use scenes tabs) if you have only SU 8 free.
            Negative of a model.skp
              With the V8 Pro if your model is 'Waterproof' (solid) you can make a boolean difference between a bounding "box" and your first model πŸ˜‰
              Damned Jeff was more speedy by 30 seconds! πŸ’š
                Maybe for the V8 free Oscollean By Oscarlok can also works πŸ˜‰
                  Jean Lemire
                  Hi Pilou, hi folks.
                  I changed my file to SU 6.
                  Best regards
                    Thanks for that! β˜€
                    Yes your second method is valuable for this sort of simple "straight object" πŸ‘
                    But maybe not with more organic object
                    With this a normal Boolean Difference should be used or your first manual method πŸ˜‰
                    http://www.110volts.net/media/catalog/product/cache/6/image/9df78eab33525d08d6e5fb8d27136e95/e/c/eclatemoteur.jpg
