    Need some help with write_image
    7 Posts 3 Posters 435 Views 3 Watching
    • jeff hammondJ Offline
      hey guys
      i'm trying to do a 2D export via ruby.. i've looked at this:
      https://developers.google.com/sketchup/docs/ourdoc/view#write_image
      so far, i've tried this:
      view = model.active_view status = view.write_image "test.png" keys = { :filename => "~/desktop/write_image.png", :width => 640, :height => 480, :antialias => false, :compression => 0.9, :transparent => true } model = Sketchup.active_model view = model.active_view view.write_image keys
      …and it returns 'false'..
      not sure what i need to change in order to get the image to write..
      any assistance will be greatly appreciated
      thanks
        Try
        model = Sketchup.active_model view = model.active_view keys = { :filename => "~/desktop/write_image.png", :width => 640, :height => 480, :antialias => false, :compression => 0.9, :transparent => true } view.write_image(keys)
        Jumbled code from the API - typically confusing 😒
        If it fails then try giving the FULL path for the filename [without the '~']...
        I'm not sure how a MAC deals with 'relative' / 'user' paths...
        On a PC ENV['USERPROFILE'] gives the user's path; onto which you can append 'Desktop'...
        The MAC will have something similar...
          ok.. that worked.. i tried a few variations on the path and finally got:
          /Users/jeff/Desktop/write_image.png
          to work..
          (whereas Macintosh HD/Users/jeff/Desktop/write_image.png ,which is the full path, fails ?? )
          i know with applescript, i can use the tilde in there as a relative path to the user.. i'll just poke around some more and see what i come up with for relative paths in ruby on mac..
          thanks a bunch!
            oh.. btw.
            what i'd really like to do, in this particular scenario, is to write the image to my clipboard instead of creating a file somewhere ..
            so, if anyone know of a way to do that, please tell..
            thanks
              I would know how to do it for Windows, using the Win32API - but I don't know what you can use on OSX. 😞
                oh.. btw.
                thanks
                I think you'll need to at least make a temporary file and use some as/terminal/shell stuff ...
                osascript -e "tell app \"Finder\" to set the clipboard to (POSIX file \"~Documents/mytemp.png\")"
                😕 perhaps
                  😕 perhaps
                  i think something like that could work.. i found a way to do it with straight applescript (still using a temp file location) which eliminates using Finder..
                  set the clipboard to (read ("path/to/the/image.png") as «class PNGf»)
