    Too many plugins
    42 Posts 16 Posters 4.2k Views 16 Watching
      lapx
      Fredo,
      so very sorry I'm getting back to you late. Your plugins are working fine. Don't know what the problem was back then. But it appears that the deletion is working.
      Thanks so much!
      • N Offline
        Nentautako
        as i'm also a newby in sketchup, i just patched my SU with plugin that i need to create motorcylces. but i have annoying thing to solve....
        how could i reorder the plugins icon in 1 or 2 rows horizontally? πŸ˜„
        this is shown in my SU blank surface....
        http://i450.photobucket.com/albums/qq221/nentautako/SDFSDFSDF.png
        • bazB Offline
          baz
          This post illustrates perfectly, imho, the common misconception amongst newbies that plugins are going to help them, (IE: Provide some sort of Magic Bullet). Of course plugins will help , but only if you understand NATIVE Sketchup.
          I teach SU and time and time again students ask, 'Can't a plugin do that?' Well of course it can, but only if you understand not only what you are trying to achieve, but also how the plugin works.
          I've said it before, and here it is again:
          THERE IS NOTHING THAT A PLUGIN CAN DO THAT YOU CAN'T DO IN NATIVE SKETCHUP.
          This a basic premise, once you understand this, then plugins become not only useful but lifesavers. But you MUST understand the basic engine first.
          End rant.
            It is BEST to introduce Plugins gradually into your workflow, so you really learn to use them, rather than being overwhelmed by them! As was just said, there is little that a Plugin can do that can't be done 'by hand' using Sketchup's own native tools... However, sometimes it is easier/faster to use a little 'helper' script... BUT, you ought to understand the native tools before you jump into the sea of plugins - at least then you'll have an idea about what they are trying to do, and even swim a little better...
            Toolbars:
            Drag the 'docked' toolbars by their anchor points and [re]locate then where you want in any of the margins, or simply leave them 'floating'.
            Docked toolbars will 'nudge' existing ones to make sufficient gaps for themselves
            If you drag a toolbar until it's 'floating' over the main window, then you can change its size, just like any PC 'window', by drag dragging a corner or a side - that way you can make a toolbar 'vertical' rather than 'horizontal' if you want to add it to a side rather than the top/bottom margin.
            You can also make 'stacked' icons - e.g. 2wx3h or 3wx6h rather than 6w or 6h - as you wont.
            You can also close a little used toolbar by clicking its 'close' button [seen once its floating], or by deselecting [no-tick] it in the View > Toolbars menu. You also use the Toolbars menu to reactivate [tick] any toolbars as needed.
            In more recent versions of Sketchup the Toolbars menu include two related options to save and to restore the toolbars' layout/state...
            • Alan FraserA Offline
              Alan Fraser
              There is a tendency with some newbies to totally pig-out on scripts. As TIG said earlier, you can actually do most stuff without them. It will take you longer, but you will learn to think in SketchUp...learn to think the way it thinks...in order to solve various problems. This is something that will stand you in very good stead further down the line when you do start using plugins and maybe need to prepare your model in a certain way before applying the script or make it easier for you to figure out why you are not getting the effect you intended once it is applied.
              Installing too many plugins is counter-productive. Not only does it slow SU up when loading, but frankly it's near impossible to remember which ones you have installed and even more impossible to remember which one does what or which is the most appropriate in any given circumstance. You need to introduce them gradually, one at a time, so that you get the chance to familiarize yourself with their use.
              I've seen some astounding figures for the size of people's Plugins folder. My own is only 54 Mb and that iincludes most of the deformation, skinning, extrusion, cleanup and UV tools by authors such as TIG, Whaat, Thomthom, Chris Fulmer, Fredo etc (which I'm guessing would form some kind of common basis) as well as a whole batch of other more specific utilities by Jim, Didier and others (apologies to anyone I've omitted), some personal scripts and the front end of several high-level renderers.
              In my humble opinion, if your Plugins folder is greater than 100 Mb, you're probably overdoing it.
              3D Figures
                A very easy way is the author sorting !
                There is a special "link" between the plugin and its creator!
                So no need of mnemonic tricks for rememberer numerous plugins πŸ˜‰
                  Alan Fraser
                  Yes Pilou, but I can't see how the author sorting would help you to decide which was the more appropriate plugin to use, for example, if you wanted to skin a particular complex shape....one of TIG's Extrude by rails, Artisan, TGI3D, one of the various loft scripts...or even the Sandbox.
                  More is not necessarily better. I'd probably advocate using fewer, but learning how to use them really well.
                  3D Figures
                    When I update SketchUp to a major version, or install SketchUp on a new computer I never mass copy all my plugins over. I install them one by one as I need them. That way I ensure I only have what I need and I get the most recent versions.
                      If you say that, it's that you use it one time, so you know their capacities
                      and know the more appropriate for your needs and preference of uses πŸ˜‰
                        Alan Fraser
                        So you are saying that if you use any plugin just once, you can remember all its capabilities...even if you don't use it again for 6 months? More than that; you can evaluate whether it is a more appropriate plugin to use than maybe half a dozen similar ones that you have also only used just once?
                        You're a better man than me, Frenchy. Up to a couple of years ago, I used Soapskin-Bubble far more than once, but I'd now need to take a refresher course in order to be able to use it at all. I couldn't even begin to evaluate it against other, more recent scripts. πŸ˜‰
                        3D Figures
                          Of course yes because I made for them some little images! πŸ˜‰
                          Sorry just the French version here (I must refind the English version πŸ˜„
                          here Soap Skin-Bubble
                          http://www.polyloop.net/imagehosting/196491035cd97702.jpg
                          so πŸ˜‰
                          • bazB Offline
                            baz
                            @nickgenerator said:
                            I am new to Sketchup and right now completely overwhelmed by all those plugins. Can I somewhere find a up-zo-date list where they are sorted by categories - modelling, rendering, import/export, etc. - and download numbers?
                            Just to remind you all. Above is the initial post. As he says, he is new to sketchup and overwhelmed by all these plugins! Oh woe!
                            He doesn't understand how plugins develop over time. He seems to expect to be informed to keep him up to date.
                            He must think this is a sort of Acad without the cost of constant paid updates. Lazy or ignorant I reckon.
                            I have a personal relationship with my plugins. I check for updates out of interest. I follow the development of a plugin out of interest.Mostly, I don't need 'em, (until I do).
                            But it is fascinating to watch the ruby gurus develop a plugin with feedback from members.
                            It is the beauty of SU and this forum.
                            Would someone with more cred than me please address this issue, which I believe has the potential to destroy "3D for Everyone".
                            I am reminded of a quote from John Brunner's book 'Zanzibar'....
                            ..." It's supposed to be automatic, but actually, you have to press this button".
                            • 2 / 3
