    How to apply texture to follow the shape?
    24 Posts 10 Posters 3.2k Views 10 Watching
    • GaieusG
      [off:35r8hidm]You have that ban button. Is that not enough? [/off:35r8hidm]
        [off:3kmxdfrp]Only thing with this is that it's ugly[/off:3kmxdfrp]
        • GaieusG
          [off:sfxlpw72]I was going to add a much more subtle (but all around) border but as it is styled now board-wise, it only adds the border to the text (rather narrow) and all images and embedded content "breaks out" of the context.
          That's even more ugly. Suggestions for some nicer styling are welcome (as always). Also, I am actually trying out different things for the future only so any changes can still be made. [/off:sfxlpw72]
            Who decides what's 'off topic' ?
            [off:b39gd0xw]The poster ?[/off:b39gd0xw]
            • GaieusG
              [off:3vyhubsh]The poster ?[/off:3vyhubsh]
              Yes. You are the poster, you apply the bbCode.
              Or the moderator when editing a post... πŸ˜’
                agamemnus
                Erm.... I still don't know how to do this.
                Oh well...
                  Oh well...
                  What have you tried?
                  • GaieusG
                    It's even easier now with Whaat's new SketchUV plugin:
                    • dereiD
                      derei
                      [off:1ufahwrn]Off-topic in relation with Off-Topic (this makes it on-topic about initial discussion here, right? - but also, off-topic about the last discussions here πŸ’š )
                      I had no idea that plugin exists, and it seems old, as is mentioned to be compatible with SU6.
                      Question: this plugin UV mapping results in a lot of textures for all faces, when exporting to some rendering software ? (like Maxwell?)[/off:1ufahwrn]
                      DESIGNER AND ARTIST DEREI.UK
                      • GaieusG
                        It's as fresh as a teenager girl. Has just come out.
                        And yes, it can export nicely, in one piece, please, have a look at this post (especially the second video in it - and then the whole topic)
                        • faBcnF
                          faBcn
                          Great tool, thanx TT!
                          One question though: is there a way to automatically create quad faces on non-quadface planar surface (you seem to do it manually from 1:32 to 1:50).
                          Two classical examples are: extruded plywood chair (such as in your example), or follow me road.
                          I would like to avoid draw lines to make quad faces on the road surface or chair border. Is it possible?
                          It could be very long process, and your tool seem to do great complicated things (likely to 3DSMax), and this simple thing seems not to exist... Maybe not that easy to program though!!
                          • N
                            numerobis
                            You can use Curviloft to generate connections between the two sides.
                            Just use "generate the junction edges (no face)" in the geometry options and then explode the result.
                            And to texture these faces i would use Thrupaint...
                              Have a look at TIGs Split Tools: http://sketchucation.com/forums/viewtopic.php?t=43376
                              (Note this is actually 4 small scripts that need installing to make them work.)
                              • 2 / 2
