    [Plugin] SectionCutFace
    565 Posts 170 Posters 361.1k Views 169 Watching
      chalky
      Tried what you said but no messages in ruby console reported. ❓ ❓
        I see you are on v7 with Lion.
        I know there were some fixes with v8M2 to address problems with Lion, perhaps that's the issue πŸ˜•
        So... any Lion users out there [with v7/v8] who are getting error free use from this tool ??
        I'm also now wondering if you have one of the problem scripts loading that can affect core class/methods ill-advisedly - these include SketchyPhysics, DrivingDimensions, MatchBox and some 'Solar' tool I cant bring to mind... Although some of these are PC only I think... This tool should workaround potential pitfalls made in its legitimate code by these files, but there might still be a trip-up somewhere. If you have any of these other scripts try to disable them and restart [move the .rb/.rbs files out of the Plugins folder temporarily].
        Does this do anything better ?
          chalky
          Sorry wrong info in profile i'm running v8
          double checked if had those plugs and I don't
            Do you have the latest v8 = v8M2 ?
            This specifically addressed some issues with Lion...
              chalky
              problem solved πŸ˜„
                @chalky said:
                problem solved πŸ˜„
                How? WE would like to know πŸ˜•
                  artsnot
                  I am new to this forum and seem to be experiencing a Sketchup crash every time I try to use section cut face. I am using Sketchup Pro 8 on a MacBook Pro i7 2.0 GHz with 8 MB RAM. I am not sure what the problem is. Has anyone else experience this?
                    What MAC OS are you using ?
                    OSX ?
                    • bmikeB Offline
                      bmike
                      Running fine on mine:
                        artsnot
                        I am running Snow Leopard 10.6.8.
                          SUFractal has reported a clash/crash with SectionCutFace [and some other scripts] if BIMtools is installed - we suspect that new tool might be inadvertently messing with native class/methods used correctly by other scripts, OR it has faulty observers that are messing with things like group creation...
                          Do any of you experiencing problems have BIMtools installed ?
                          If so, try disabling it and retry/report back...
                            artsnot
                            How does one do that? Sorry, I am totally new and have no idea what that means. I appreciate your help.
                              Well... first have you [recently] installed BIMtools?
                              If not don't worry.
                              BUT if you did, then find the file you installed in Plugins - look inside the original 'zip' file to see what these were. There should be 'bim-tools.rb' and its folder of other files that it uses.
                              So disabling 'bim-tools.rb' in Plugins will stop it auto-loading.
                              You can either move that file out of the Plugins folder temporarily so Sketchup doesn't then find it when starting, so it is not auto-loaded; OR you could leave it where it is and rename it 'bim-tools.rb!' - only file-types '.rb' and '.rbs' are auto-loaded.
                              If you restart and try SectionCutFace now does it work...
                              If so we have the culprit...
                              If you want to restore a disabled tool later on, then either move its file[s] back into Plugins, or if you have adopted the other approach, rename the file[s] back as 'xxx.rb' etc...
                                artsnot
                                I don't recall having installed anything like that and a spotlight search reveals no files with such name. I've checked my SU folder as well and there doesn't seem to be any such script. Thoughts?
                                  Post a detailed screenshot of your Plugins folder showing what is installed.
                                  Also post the full path to the folder...
                                    SUFractal
                                    If not don't worry.
                                    Folks ... the correct name of the troublesome script is 'SketchUpBIM'.
                                      artsnot
                                      Here you go.
                                        artsnot
                                        Could my problem have to do with using Podium for Sketchup? When I try using Zorro to cut my model it also crashes immediately.
                                          You have very few scripts auto-loading from Plugins...
                                          You could try disabling both Zorro and Podium temporarily - add a ! onto the end of the file extension to prevent it auto-loading on a restart of Sketchup.
                                          Later on you can remove it back to .rb/.rbs as appropriate, so it enabled again.
                                          It's strange that you and a few more now and again have issues as it's been around for ages without problems...
                                          Open Window > Ruby Console when running the SectionCutFace and see if there are any error messages when it fails.
                                          Also in the Console type $LOAD_PATH [exactly as here] and there should be a list of the folders Plugins [for 'your' scripts] and Tools [for Google's scripts]; are there any other folders listed there that contain .rb/.rbs files ?
                                          Can you post the SKP that has the issue so we can text it.
                                          Can you also ZIP the actual script [.rb] and PM it to me so I can check it hasn't somehow become corrupted during your install... by ZIPping it it'll preserve its contents best...
                                            danylight
                                            why is sketchup closing when I use the section cut face ?? does anyone experience the same issue ? I used to work with this great plugin, I reinstalled sketchup ( same version as before, 8.0.3161 ) and now it doesn't work anymore...
                                            I work with OS X 10.6
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 28
                                            • 29
                                            • 14 / 29
