    Draw a face normal to a single 3d edge
    4 Posts 3 Posters 323 Views 3 Watching
    • brookefoxB
      brookefox
      I can't seem to quickly draw a face normal to a single 3d edge somewhat near flat, without spending too much time constructing guides, etc. Is there a plugin or an easy way? Even when constructing guides and the like, if the normal up is close to blue, no can do; I can get the perps to the side.
      In this example, I think the loft is screwy reversing because the faces are not normal to the path, though I could be wrong about that. (Fredo Curviloft)
      ~ Brooke
      • mitcorbM
        mitcorb
        Well, Chris Fullmer has his Perpendicular Face Tools. You could take one of his stock shapes and maybe modify it to your taste after having placed it. I have not tried this, yet. But then, there may be something else out there?
        • Wo3DanW
          Wo3Dan
          @brookefox said:
          I can't seem to quickly draw a face normal to a single 3d edge somewhat near flat, without spending too much time constructing guides, etc. Is there a plugin or an easy way?...
          One of Chris's plugins, mentioned by Tim.
          With SU's basic tools: re-align the axes, one along the paths first segment. The other two axes then are perpendicular to that segment. Now the circle tool will draw a face perpendicular to the path (orbit to look mostly along that first segment)
          • brookefoxB
            brookefox
            Thanks so much, guys. I will look for Chris' tool but the native way I should remember! Chris' tool looks perfect, Tim.
            ~ Brooke
