    Vray for blender
    renderpluginsextensions
    38 Posts 8 Posters 6.4k Views 8 Watching
    • StinkieS Offline
      Stinkie
      Yeah ... bmesh looks good. Its bevel tool still needs some work, though.
      • andybotA Offline
        andybot
        well, vray has a round edges. That's one thing I want to play with sometime.
        • andybotA Offline
          andybot
          quick DOF test.
          • holmes1977H Offline
            holmes1977
            Thanks Anybot
            This is very exciting. Ive started to watch some video tutorials. Seem all very compatible to what we know in Vray4SU.
            Have you already purchased the standalone or are you still using the demo versions.
            Exaggeration makes a dull story better.
            • andybotA Offline
              andybot
              Hey Jonathan - I did buy the license. Once I installed the vray for blender build and saw how good the integration is with vray, I knew right away it would be worth the purchase. I had been trying other blender rendering add-ons earlier - luxrender, thea, yafaray, cycles, but none of them were doing it for me. Also, I never did get indigo to work, nor renderman. Anyway, with vray, there's just no comparison.
              • eidam655E Offline
                eidam655
                i'm especially surprised by the looks of the rounded edges... but i guess that's a SketchUp thing, rather than VRay's, right?
                I'm using SketchUp 2017, V-Ray 3.4
                • andybotA Offline
                  andybot
                  Well, now that I play with it more, that's actually mostly a subdivision issue. Here is the same vfsu scene with 2 iterations of SDS instead of one.
                    holmes1977
                    I suppose blender/vray will really come into its own when dealing with heavy scenes. Have you played with proxies/instancing yet, or a textured model that would normally given you a hundred bug splats?
                    • andybotA Offline
                      andybot
                      I'm working on a big scene as I have time. I'm finding it's quite a bit of cleanup to export something with a lot of components.
                        holmes1977
                        i suppose you will start collecting high poly better models to use anyway. Oh bring on evermotion models Yummmmmmmmmm
                        • pugz1983P Offline
                          pugz1983
                          I've scratched the surface of blender to and the possibilities are good in my opinion. The only thing i havent figured oput yet is the best format to export to Blender. I don't want to spend a lot of time organising the model hierarchy in Blender. Love some pointer on the export to blender workflow.
                          Greetz Twan
                          • andybotA Offline
                            andybot
                            Hi Twan,
                            I'm still trying to figure out the best methodology too. So far, the two options that have worked are using SU pro native 3ds exporter, and using TIG's object exporter
                            My wineglass and lamp was brought in using the 3ds export. The group and component heirarchies are kept, and the shapes came in properly as meshes. I added smoothing and subdivisions, adjusted the materials to it to the render.
                            The objexporter gets rid of the heirarchies and groups things by material. This is useful when there are lots of small groups and components that can make it hard to navigate the model. It's also helpful because you can easily replace material since there's one mesh per material (there may be a global way to replace, I just haven't figured it out yet.) The big issue I've run into is that duplicate vertices are exported, but that has a relatively easy fix thanks to michalis' tip
                            There are still more parts of the workflow I am testing as I have time, but hope this gets you in the right direction.
                            -Andy
                            • pugz1983P Offline
                              pugz1983
                              Thanx for the tips Andy. I'll give it a go when I get back from work today. After looking at the trailer of the Nature Academy Tutorials I really started to get interested in Blender. Do you use Blendup to make the controls more like in SU?
                              Greetz Twan
                              • dkendigD Offline
                                dkendig
                                I'm surprised 3ds worked better than the collada format (*.dae), I thought that was supposed to be the end all be all format these days.
                                Devin Kendig
                                Developer
                                • andybotA Offline
                                  andybot
                                  Collada just doesn't seem to be that well supported. It seems like it breaks regularly with Blender updates.
                                  @pugs1983 - I'm fine with the blender interface as it is v2.5 and higher. It's the rotate, zoom, pan that's been "fixed" from earlier versions that makes it easy to use.
                                  • 2 / 2
