    "Access to 0.skb was denied."
    6 Posts 3 Posters 9.6k Views 3 Watching
      mrjumpmanv2
      I wouldn't normally mind this but it seems to pop a window saying "Access to 0.skb was denied." up every few minutes and i have to close it every time, which is pretty annoying...If it helps to know, i've been downloading a few plugins recently and that seems to have caused the problem. If no one knows it's not a huge problem cause i could just install sketchup again and it will probably go away.
      help would be much appreciated!
      %(#000040)["Anyone who has never made a mistake has never tried anything new."
      Albert Einstein]
        Probably a slow network issue, or you are working off a memory-stick, or you have limited access-rights to the folder you are [currently] working in ?
        πŸ˜•
          mrjumpmanv2
          Thanks, i found the problem though, there was a file called 0.skb in documents and for some reason it was telling me it couldn't open even when i wasnt tring to. the reason i couldnt find the problem before was cause when i searched "0.skb" and it wouldnt show up.
          Albert Einstein]
          • Dan RathbunD Offline
            Dan Rathbun
            Are the "skb" files those saved by the AutoSave or Backup feature ??
            Changing settings in "Preferences" > "General" may help.
            I'm not here much anymore.
              I think what happens is when you have a skp and a matching skb, and do a 'save' the skp needs to first be renamed as the new skb and then a new skp made, the '0.' files are an intermediate step. If one already exists the next number is used. If you have a slow network or are using a memory-stick etc these files can get 'left behind' and when next they come to be 'used' it cause issues...
                Dan Rathbun
                Sounds like a bug.. you'd think it would be safer to use a timstamp in the name of the "temp" skb file.
