    /!\ Can't adapt a .mat material , need help , uber importan!
    renderpluginsextensions
    11 Posts 3 Posters 4.6k Views 3 Watching
      MaloneXI
      Hi all ,
      As everybody knows , Vray does not accept .mat matérials. So , I decided to adapt the material I have chosen to make it available in sketchup.
      Big problem , I don't understand the tree of the /mat texture , where to place the map , the fresnel , etc.
      So , if possible , I need someone who could help me. I got 3DS max , but I don't recongnize where to put the same parameters from max to sketchup's.
      Anybody could help ?
      This is the joined material. All I need is 5-10 minutes of someone's time to explain me how to do. I see the parameters in the 3DS MAX material tree , but it doesn't seem to be the same in sketchup.
      And I really need this material , it's for an interior design , and this pure metal is perfect for IPN beams , etc.
      Please , help me
      Metal oily and dirty_by_Banshee1548.rar
      • V
        valerostudio
        Max has a much more robust material editor. This is a close match. Attached for all to enjoy!
        Metal Oily Dirty.zip
        • V
          valerostudio
          Doesnt tile very well, but a little Photoshop can fix that.
            MaloneXI
            You.are.my.hero.
            Glory to you.
              MaloneXI
              mmmm...I'm sorry man , but your material doesn't load anymore. It loaded just one time , and now , I can't use it anymore. 'dont know why....
              When I open the material , importing it to change the first one , it diseappears from the mat list...
              if you could help ...
                MaloneXI
                I just installed Material studio, but you .vismat can't load . Maybe you did an error ?
                  AMELIEBOB
                  Hi, is there any possibilities of explaining how you've made this material?
                    MaloneXI
                    Hi , in my opinion , there is too much bump inside de file.
                    Still in my opinion , the tree of the material is a little bit more complicated that you did. It's a great work you made , but tue the result is not the same.
                    I made it by my own, trying to do my best.
                    that is yours :
                    http://img11.hostingpics.net/pics/874411t02.jpg
                    Not so bad uh; I think just a little bit coarser than the original.
                    mine :
                    http://img11.hostingpics.net/pics/520146t01.jpg
                    I tried to play just with specular channels , not bump. An Iron Sheet like that , pure, doesn't have any bump once it's treated. Just a "blury shine" over its surface.
                    But be careful , in the comments , on the texture I linked , in Vraymaterials.de , people talk about the too long time rendering the texture.
                    Making a material less complicated could be better.
                    @amelibob : I will post the detail of the material tree this evening , at the moment I don't have the time to.
                    And the result.
                    http://img11.hostingpics.net/thumbs/mini_8548404716.jpg
                    I will certainly paint the IPN beams in black , I think. But for now , the industrial visual of them is good to now.
                    • V
                      valerostudio
                      Material Studio will not work with new materials made in 1.49.01
                      The Mat Studio is base on the old 1.05.30 version
                      • V
                        valerostudio
                        Diffuse is the supplied jpeg material
                        Added a Reflection layer set to Fresnel IOR of 6
                        Added a filter map to reflection using same supplied jpeg material
                        set glossiness and highlight to .85
                        Set Subdivs in reflection to 35
                        Added a bump map using same supplied jpeg material
                        You can adjust the bump as needed. I used .7 assuming it was a rough scratched material, turn off if you want
                        Adjust the reflection glossiness if you want a duller material (.65 will be very dull)
                        If renders are slow, turn down the subdivs in reflection (35 is high but give a HQ result) You can get away with 18 sometimes.
                          MaloneXI
                          Great thanks man , I was kinda lost with that material.
                          Thanks again.
