    [Plugin] AreaTextTag
    97 Posts 27 Posters 88.2k Views 27 Watching
    • Z Offline
      ZFRPS
      Dear Tig:
      good job!The CSV reporting is my want,Very slow when reporting ....
      sketchup is bim
        Its 'slowness' is because it must find all text-tags in the current context by sifting out other things, then it must 'update' them in case a tagged face has changed since the last update, it also must check for tags that are no longer glued to a face and ignore them, and also for duplicate tags placed on the same face and so on [this can be done beforehand using 'Update' manually, which might speed up the CSV a little]... the writing of the CSV file itself is relatively quick once the updating concludes... 😉
        I noticed that your CSV toolbar button icon is missing - I have missed it out of the subfolder set.
        I'll add it to any future updates, but meanwhile if you substitute/add these two PNG files into the tool's subfolder it will fix the missing icon...
        • Z Offline
          ZFRPS
          Dear Tig:
          Here amount only:1001006=60000;slow !!Half an hour past it no finish!
          if csv change to xml ?
          or other way ?
          Thanks again !
          sketchup is bim
          • Z Offline
            ZFRPS
            OK!
            Irrespective !
            I only look forward to it change to very very quickly !
            Your job is great for all SU-FANS,I love you !
            THANKS AGAIN
            sketchup is bim
              ArCAD-UK
              TIG, Many thanks for developing this.
              I have just downloaded the RBZ and have tried a few variations of tagging but keep getting zero perimeters. The areas are working as expected with simple rectangles and no grouping. Bug or have I missed something?
              Update: If I change "Report Surface Area" to Yes then perimeter is reported.
                You must apply an area tag directly onto a face.... how the hell is it going to know what face to use if you apply it onto a group or instance ?
                So... in the same [edit] context as the face you want to tag pick that face to add an area tag onto it.
                If you later export those tags from that context into a CSV file the faces' areas and the faces' perimeters are returned...
                The 'surface'=Yes tag is intended for adding area-tags to bound-faces that are 'facets' with hidden/smoothed edges, forming a 'surface' where you want the one area reported for all of them together, getting the perimeter of a 'surface' is much more complex than with a face [in fact it's too complex!]...
                  ArCAD-UK
                  Hi TIG, as per my update I was advising that with "surface" = No then the perimeter is not exported to the CSV which is what I was expecting. I now understand your reasoning and will default to "surface" = Yes.
                  Just a suggestion, reporting the perimeter in both modes may be more logical to the end user, but you know better than most what can be achieved with the coding.
                  Thanks again for another great contribution!
                  • guanjinG Offline
                    guanjin
                    Can not correctly display units.
                      If the chosen font has no superscript 2 '²' it won't be shown.
                      What font is used?
                      Do you get one with other fonts [use the Settings dialog to adjust various aspects of the AreaText tags] ?
                      It might be your Chinese OS ?
                      Do you get any error messages in the Ruby Console [I'd expect not, because 3dText simply skips over missing characters in a font's collection].
                      If you copy paste this [ 1.23 m²] into the native 3dText tool's pane, for the same font [Arial?] what gets made ? Does the final '²' appear or not ??
                      This is what my Arial-Font AreaText tag looks like...
                      • guanjinG Offline
                        guanjin
                        I choose Times New Roman, but the display unit does not
                          Have you tried my copy/paste suggestion using the native 3dText tool ?
                          • guanjinG Offline
                            guanjin
                            Paste the local, show normal
                              It works fine for our western PCs? 😕
                              As a temporary fix...
                              Edit the main .rb file inside this tool's subfolder using Notepad.exe.
                              Find the 4 occurrences of the text
                              .gsub(/2/,"²")
                              and change it to read
                              .gsub(/2/,"2")
                              then you will get
                              1.23 m2
                              instead of the intended [but failing]
                              1.23 m²
                              which whilst not perfect it is better.
                              If you would prefer
                              1.23 m^2
                              then change the replacement text
                              .gsub(/2/,"2")
                              to be
                              .gsub(/2/,"^2")
                              • guanjinG Offline
                                guanjin
                                Thank you, of TIG: has been resolved, thanks again!
                                  jeff2047
                                  got it, thanks share
                                    Bokkie
                                    hi, was wondering if this plugin will / could, extract or copy an atrribute's value, when inserted into a block with attributes?
                                      It reports the area of the face it's 'attached' to.
                                      The face/tag need to be in the same context.
                                      It doesn't 'report attributes'.
                                      There are other tools that do that, but you need to be somewhat clearer in your question...
                                      • F Offline
                                        ffox
                                        Thank you, I am finding all of this really helpful.
                                        I searched through the chain and don't think that this has been addressed yet. I am wondering if it is possible to input two text entries per tag. For example, "room #" and "department" both associated with the same square footage, so when exported, you have two text columns per sf which can be sorted accordingly.
                                        Thanks in advance!
                                          gclyde
                                          Would it be possible to select and group a number of faces and give a tag that relates to the total surface area of all selected faces?
                                          In addition, would it be possible to produce a similar ruby that totals up the lengths of selected lines/junctions? (not necessarily the perimeter of a face)...this would be icing on the cake for me 😍
                                          Graham
                                          • atelierpaarA Offline
                                            atelierpaar
                                            Hello TIG
                                            Great script !!
                                            Since I am always short in space it would be of great help if it would we possible to have 2-line Text-Tags for instance :
                                            Entrance
                                            30 m²
                                            alignment options
                                            • Left
                                              Right
                                              Center
                                              Thanks for looking into it
                                              Uli
                                            • 3 / 5
