    How to measure a part of curve?
    extensions
    6 Posts 4 Posters 954 Views 4 Watching
    • tibetT Offline
      tibet
      hi,
      i´d like to extract an exact distance from a curve, but somehow forgot how to do it 😄
      thanks
      http://img.acianetmedia.com/i/T1V64.jpg
      http://i52.tinypic.com/zujcp1.jpg
      SU 2015 Pro on Win10 x64
      • mitcorbM Offline
        mitcorb
        Well, there is C=2 pi r. If you happen to know the angle subtended by the arc, or if you know the fraction of the circle. I assume you mean true length, not Sketchup segment length(chord).
        • dereiD Offline
          derei
          or you can just make sure that curve has enough segments (the more segments - the greater the precision), then explode it, select the segments that cover the length you want to measure, and look in Entity Info, there you will see the length.
          • tibetT Offline
            tibet
            hi ,
            thanks for a quick answer, i need it to extract the curve fysically to use for another plugin.
            i thought measure tool can do the magic:-)?
            is there other any measure plugin for this purpose to measure a distance of wide of variety of shapes, specially need for cad purposes?
            best of luck!
            • tibetT Offline
              tibet
              hi dereeei,
              thanks a lot !
              a great idea, it helps a lot !
              cheers!
                In all recent versions of SUp the 'Entity Info' dialog should report a selected Arc's 'true length' and NOT the total of its segments.
                To test this change the Arc's segment count in 'Entity Info' and you'll see irrespective of if it's 3 or 999 the reported 'length' remains the same - whereas exploding into lines copies of that same arc with differing segment-counts will report their cumulative lengths as differing...
