    Angaston pavilion
    36 Posts 20 Posters 5.1k Views 20 Watching
    • allanxA Offline
      allanx
      Very nice! Especially the grass...
      allanx
      Portfolio
      • massimoM Offline
        massimo Moderator
        Thanks guys. ๐Ÿ˜„
        Here are some Thea's wires. Well pretty an heavy instancing...
        • soloS Offline
          ๐Ÿ‘
          Thanks a bunch, nice to see the Thea wires as it explains the scene so well and shows the incredible amount of poly's used for a true full 3D vegetation filled scene.
          • brookefoxB Offline
            brookefox
            Yes. Nice render: structure, setting, vegetation, lighting; nice work itself, the architecture. Somewhat reminiscent of current starchitect Kundig work, and that is a weightless observation.
            ~ Brooke
              brookefox
              Your rendering looks like it sits near wetland... and makes it look nicer than it is, perhaps (the immediate scene).
              ERROR: The request could not be satisfied
              (www.archdaily.com)
              ~ Brooke
              • tridemT Offline
                tridem
                ๐Ÿ˜ฎ stupendo ๐Ÿ‘
                • mitcorbM Offline
                  mitcorb
                  Yes, absolutely great job.
                  • boofredlayB Offline
                    boofredlay
                    Inspiring work. Love it.
                    • massimoM Offline
                      massimo Moderator
                      Thank you very much guys. ๐Ÿ˜„
                        Cool adaptation! ๐Ÿ˜Ž
                        • DanielD Offline
                          Daniel
                          Outstanding work, Massimo.
                          My avatar is an anachronism.
                          • massimoM Offline
                            massimo Moderator
                            thanks Pilou and Daniel. ๐Ÿ˜„
                            • Bryan KB Offline
                              Excellent work.
                              • holmes1977H Offline
                                holmes1977
                                OUTSTANDING, great feel in yor renders.
                                Exaggeration makes a dull story better.
                                • cheddaC Offline
                                  chedda
                                  Definitely Murcuttesque with the rust metal lattice feel, very successful !
                                  Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                  • massimoM Offline
                                    massimo Moderator
                                    Thank you. ๐Ÿ˜„
                                      archkeenidea
                                      nice style , love it ๐Ÿ‘
                                      • eidam655E Offline
                                        eidam655
                                        looks nice ๐Ÿ˜„ so the grass is only a rectangle with an alpha texture and copied all over the place?
                                        I'm using SketchUp 2017, V-Ray 3.4
                                          Roger
                                          Where can I learn the work flow involved in the instancing? Is that one 3D plant" Are any of the parameters of the plant randomized in each instance? Is the placement of the plants done on SU or in Thea?
                                          http://www.azcreative.com
                                          • massimoM Offline
                                            massimo Moderator
                                            Thanks guys. ๐Ÿ˜„
                                            No it's 3d. Haven't modeled it myself though.
                                            In Thea of course, all that 3d vegetation would easily kill SU.
                                            Actually it is quite simple: it's almost like Kerkythea but of course more powerful. You have to input a canvas (a portion of the terrain defined by a material) and an instance (the model of the grass or of a tree) and then you can use a "populate" command or a "brush" tool. Each tool is customizable.
                                            I've used four different instances for the grass and two for the trees. Anyway you can assign to each package of instance+canvas (and that will affect randomly each generated instance) parameters such as Direction, Normal, Roll, Scale (percentages), Minimum distance (meters) etc.
