    Circular construction lines
    5 Posts 4 Posters 696 Views 4 Watching
      geone
      can someone tell me how to (or if it is possible at all) achieve a circular construction line (the same as one gets with the offset tool)?
      mucho thanks
        Aerilius
        construction lines are only available as straight lines and half-lines. How did you get a construction line with the offset tool? Do you have a screenshot?
        • liquid98L Offline
          liquid98
          Use plugin xline
          http://rhin.crai.archi.fr/rld/plugin_details.php?id=486
          Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
            geone
            I used the term offset to indicate the effect I would like to achieve.......thanks for the heads-up. I guess you could use the offset for a reference line and then delete it...
            thanks mucho
            • brookefoxB Offline
              brookefox
              The tools on surface plugin can draw lines or construction lines and draws on curved surfaces. You might try that (I have not).
              ~ Brooke
