    I invite for acquaintance with Russian plug-in
    77 Posts 18 Posters 23.4k Views 18 Watching
    • yad2000Y Offline
      yad2000
      @jorge2011 said:
      thanks for the update. very interesting.
      a query:
      The plugin generates the following error:
      Error: # <ArgumentError: Not enough-at least 3 edges required>
      C ๐Ÿ˜• Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in add_face ' C :/ Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb: 552: in cp_create_pipe_geometry '
      C ๐Ÿ˜• Program Files / Google / Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb: 110: in `OnLButtonDown '
      you can fix that? thank you very much
      What are you trying to do when there was this error?
      @driven said:
      hi,
      it looks great but doesn't run on mac.
      what does the .dll and .so contain, is there a mac equivalent?
      . dll and. so standard libraries contain Iconv, to work with different encodings. The plugin was created for the Russian language for Windows, unfortunately for MAC to configure the plugin I have no technical ability (I hope to understand.)
      Iconv needed to process W-1251 encoding in UTF from time to time by the return webdialog
      CoolPipe Plugin
        jorge2011
        try to draw a pipe, and just draw a vertical line and generates the error
        • yad2000Y Offline
          yad2000
          very strange ...
          probably something with the settings of the sketchup
          or platform
          or something else))
          CoolPipe Plugin
          • yorik1984Y Offline
            yorik1984
            I tested plugin. If you have in your plugin directory this plugin:
            http://forums.sketchucation.com/viewtopic.php?t=41840
            http://rhin.crai.archi.fr/rld/plugin_details.php?id=219
            SU shutdown with error!
            • yad2000Y Offline
              yad2000
              plug-in works correctly on a 32 - x bit Windows, sometimes there is an incompatibility with some third-party plug-ins
              CoolPipe Plugin
                driven
                I had to change all the Sketchup:: require'' to require '' to return true and see the Toolbar.
                If I comment out all 'Iconv' references in all the files, Webkit on mac appears to handle the Cyrillic encoding without any issues.
                Is
                <script type="text/javascript" src="js/documets_pack.js"></script>
                still needed? I get an error.
                If I change ini.rb to "Lang=en", on start I get a message box Did not load RB script&#058; /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb
                if I start with Lang=ru and then change ini.rb and reload, I get
                Error: #<TypeError: /Library/Application Support/Google SketchUp 8/SketchUp/plugins/CoolPipe/coolpipe_Start.rb:81:inadd_item': can't convert nil into String>`
                I can't get much further without English, but will keep trying.
                • Dan RathbunD Offline
                  Dan Rathbun
                  OMG! WHAT A PIECE OF CRAP.
                  Denis .. you MUST wrap all your code inside a module.
                  You are defining class veriables and all your methods within Object, and they propagate into everyone else's classes and modules.
                  I do not recommend anyone use this plugin until it is fixed, and properly module wrapped !!
                  I'm not here much anymore.
                    Dan Rathbun
                    WARNING !!
                    This "plugin" (term used loosely,) does very bad things to SketchUp's Ruby environment !
                    It includes Math module into Object, which will propagate into EVERYTHING else.
                    Also it modifies Integer, Float and Fixnum baseclases, by including Math (again), and defining plugin specific methods (that are not really needed anyway.)
                    • yad2000Y Offline
                      yad2000
                      @driven said:
                      Is
                      Work on the multi-language version is started, the news wrote about this on your site. Much more needs to be done (not without some help users of course).
                      The plugin is provided as is and use it to recommend your own risk.
                      @dan rathbun said:
                      OMG! WHAT A PIECE OF CRAP......
                      Please calm down!
                      I am not a programmer proffessionalny Ruby, do what learned.
                      I do not claim to uniqueness and correctness of their decisions. Your comment will take into consideration and try to make changes with the next version.
                      As the saying goes do not like do not eat, and you should not call all the crap.
                      CoolPipe Plugin
                      • yad2000Y Offline
                        yad2000
                        #-v1.2.1
                        Multi-project choice of language in the process of working with the plugin
                        Calculation of the mass-removal (steel), raschityvatesya of geometrical parameters (may not fit with factory products)
                        #-The structure of the code changes: there is no change in the standard classes, all of the code integrated into classes and modules
                        #-correction made for loading iconv.so: The MAC does not load, only on Windows
                        edit-elements located outside the Observer in the allocation of a separate command button
                        #-fixed principle of sorting elements of the standard specification. sort (to avoid memory leaks in the process of counting and hangs SketchUP)
                        CoolPipe Plugin
                          jorge2011
                          thanks for the update. But still generates the same error, when using the tool "tube":
                          Error: #<ArgumentError: Not enough edges - at least 3 required>
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:569:in cp_create_pipe_geometry'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:110:in `onLButtonDown'
                          C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:247
                          you can fix it?
                          I use:
                          windows xp in Spanish
                          sketchup 8 pro in Spanish
                          • kenK Offline
                            ken
                            I receive the following error code after installing.
                            Thanks you in advance for your help.
                            Ken
                              jorge2011
                              Ken
                              You must copy the file "iconv.so" in the folder:
                              windows/system32
                              • kenK Offline
                                ken
                                Jorge
                                Will thanks for the advice, however I still have the same error code.
                                Ken
                                • guanjinG Offline
                                  guanjin
                                  Site not open
                                  • yad2000Y Offline
                                    yad2000
                                    you can fix it?
                                    I use:
                                    hmm ...
                                    very strange ...
                                    I was not able to repeat that mistake, I can recommend:
                                    Line number 569 is:
                                    face = entities.add_face circle
                                    Try replacing the line number 557:
                                    circle = entities.add_circle pt1, vecbegin, radius, numsegs
                                    on the line
                                    circle = entities.add_circle pt1, vecbegin, radius, 24
                                    or if not, then the line
                                    language is not involved, but rather a problem of API in your version of SketchUP, although the design:
                                    works with the version of SketchUp 6.0+, can you have an earlier version, not 8.0 PRO? in a previous version of the plug CoolPipe 1.2.0 you have the same problem was, nobody else it is not repeated
                                    CoolPipe Plugin
                                      jorge2011
                                      This solution does not work.
                                      the list of error:
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570:in add_face' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:570:in cp_create_pipe_geometry'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:110:in onLButtonDown' Error: #<NoMethodError: undefined method bounds' for nil:NilClass>
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:90:in creategeometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:67:in onLButtonDown'
                                      Error: #<NoMethodError: undefined method bounds' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:90:in creategeometry'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/TeeTool.rb:68:in onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/ReducerTool.rb:90 Error: #<NoMethodError: undefined method bounds' for nil:NilClass>
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in creategeometry' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:67:in onLButtonDown'
                                      Error: #<NoMethodError: undefined method bounds' for nil:NilClass> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in creategeometry'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:67:in onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90 Objeto elegido CoolPipe = Error: #<NoMethodError: undefined method []' for nil:NilClass>
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:594:in getparams_frompipe' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:327:in reset'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:296:in initialize' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:3070:in new'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:3070:in cp_edit_coolpipe_elements' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:21:in cp_add_toolbar_button'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90:in call' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/FlangeTool.rb:90 Error: #<NoMethodError: undefined method layer' for nil:NilClass>
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/PipeTool.rb:594 Error: #<NoMethodError: undefined method layer' for nil:NilClass>
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in onLButtonDown' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67 Error: #<NoMethodError: undefined method length' for nil:NilClass>
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2819:in cp_get_length_tube' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2931:in generate_CoolPipe_specification'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2925:in each' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:2925:in generate_CoolPipe_specification'
                                      C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/Service_proc.rb:25:in cp_add_toolbar_button' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/CoolPipe/CopyOptionsTool.rb:67:in call'
                                        Dan Rathbun
                                        @yad2000 said:
                                        Line number 569 is:
                                        try:
                                        face = entities.add_face( circle.edges )
                                        • yad2000Y Offline
                                          yad2000
                                          That's right, because you're not going to work. This plugin is targeted to the appropriate users. You have added a new document and a new tube without any parameters, of course anything you do will not work. The parameters necessary to specify everything: nominal diameter, outside diameter, wall thickness, the name of the pipeline, etc. All that is required.
                                          So that promote your cause, or assist in the development or discourage new users
                                          CoolPipe Plugin
                                          • yad2000Y Offline
                                            yad2000
                                            Please bring a list of documents for which you want to add elements. Now used only 2 Russian document on the piping. If you write a number of documents that you use and you can download them somewhere, I'll add them to the database to avoid similar mistakes.
                                            CoolPipe Plugin
                                            • 2 / 4
