    Curve Help
    4 Posts 3 Posters 300 Views 3 Watching
      Cubcrafter
      Attached is a file of an airplane that I am working on. It has a tail cone and I am at a loss of how to draw this. I don't know which plugin to use to make this.
      Also a photo is attached of the tail cone on the aircraft.
      Any help would be appreciated.
      Thanks,
      Larry
      • numbthumbN Offline
        numbthumb
        Fredo´s Curviloft?
        Btw it is a very dense mesh 😕
        Master375ScaleSTA - Copy.skp
        Comfortably numb...
          It is TOO dense! I suspect that even the real aircraft will not be so 'smooth' !
          7000+ facets in each half of half of the tail-cone!
          My ExtrudeEdgesByRails will also make the two pieces for you.
          It would benefit from all Profiles and all Rails in 'a set' having the same number of segments...
          The single edge must be divided and welded into a straight cure to match its partner on the other side...CaptureUnsmoothed.PNGCaptureSmoothed.PNG
            Cubcrafter
            Thanks TIG,
            I was able to reproduce what you did. With the central rail the shape seemed to flatten out to much at the point so I did one without the central rail and it looks better.
            Seems that the key is that all sections have the same number of segments and determining just how many segments are required to get a smooth surface.
            I will probably make a mold for this piece and make it out of fiberglass.
            Thanks,
            Larry
