    Will NOT scramble ??
    44 Posts 4 Posters 3.0k Views 4 Watching
      😒 OK... perhaps I should have said something like using 'FILE' won't work inside a .rbs compiled script consistently...
      When a Ruby runs it has FILE got from the script's own path, which is unique to each script.
      When a .rbs runs with the FILE code compiled within it, you cannot assume that it will return the path to the .rbs file itself, so if it's returning the path to the 'executing app' it might just work for one .rbs, but then not for any others subsequently, because FILE will NOT point at the .rbs file itself and will have been added to the file_loaded's array already !
      I can't see why you are spending so much time trying to compile a 'menu setter' - just make it a .rb - that way it's transparent to the user and won't have these issues, it makes the menu items/toolbars etc and required the .rbs files from their subfolder - it's a 'loader'...
      Then your compiled .rbs files [without any need to include 'menu code'] can go into your tool's subfolder where they belong with the other files a complex tool needs... This is the 'proper' way to do it... IF you must protect your code by compiling it...
      At the moment getting you code to run properly is much more important, but if you compile it no one can look at it to help you debug because decompiling a .rbs file is not possible...
        ksor
        @tig said:
        :roll: OK... perhaps I should have said something like using 'FILE' won't work inside a .rbs compiled script consistently...
        When a Ruby runs it has FILE got from the script's own path, which is unique to each script....
        Ha, ha, I think I'm the one who should do the 😒 😒 😒 !
        Can I ask (and get an answer of cause ) is the SCRAMBLER just a prototype ?
        And please don't turn the focus to me trying to scramble menu setting - that's not the point - it's just a smokescreen over the real problem I think.
        Even this simple code doesn't work when scrambled and loaded as an extension:
        require 'sketchup.rb'
        class Polley
            # store bogstaver evt. med _ er en CONST
            MINDIAP = 50.mm
            MINDIAA = 10.mm
            MINKRVD = 25.mm
            MINKRVB = 15.mm
            def initialize()
        UI.messagebox("A")
            end #initialize
            def draw_pulley()
            end # draw_polley
            def input_dialog()
            end # input_dialog
            def makePulley(diaP, diaA, krvD, krvB)
            end # makePulley
        end #class
        The "A" never comes up 😠 😠 😠 - maybe the scrambler IS a prototype - then just say it then.
        Best regards
        KSor, Denmark
        Skype: keldsor
          You only need to call
          once in a session [it might have been called earlier by another script anyway],
          do should that in your 'loading' .rb file that makes the 'extension'.
          Then you can omit it from the .rbs because it's already loaded...
          OR alternatively try to use
          Sketchup::require 'xxx'
          inside a compiled script, which should work...
            The scrambler is not a prototype.
            It started as @Last's then taken over by Google...
            So it has been around for many years, but it has always had such issues...
            But then a few simple ground-rules when devising the set up of your code avoids them.
            I don't understand your antipathy 😕
            Either work with what you've been given [taking into account the advice we give freely and kindly], or forget about scrambling things altogether until you are really 'up to steam' on Ruby scripting with the API, OR if you have the ability then write a better scrambler and explain to us how to use it !
              ksor
              Ha, ha just a new smokescreen ....
              Whether or not I have the "require 'sketchup.rb'" is not the point - and it has NO difference on the problem !
              The point is if the scrambler IS a prototype or NOT ... and you have not a single word about it 😒 !
              I remember to have read somewhere in this forum, that it maybe would be a good idea to write a better scrambler .... I would add: maybe a better interpretor too - not to mention an editor with some intellisence .... that would be really nice.
              There is much too much 'really low level' debugging going on in what should be a high level language.
              .... but take Ruby as it is or leave it !
              Best regards
              KSor, Denmark
              Skype: keldsor
                If you make an extension, using SketchupExtension, which loads a .rbs file you'll get namespace trouble.
                Say you have a plugin written in module FooBar stored a .rbs loaded via SketchupExtension then it will beloaded into SketchupExtension::FooBar instead of the expected root namespace. I seems that SketchupExtension eval into its own namespace. I ran into that problem with Vertex Tools - and because of that had to make an unscrambled proxy loader to ensure everything came into the correct namespace.
                  So when you do tried Polley.new nothing happened - no error at all?
                  Your example didn't include anything about how you tested it - maybe there is something there.
                    ksor
                    I just did the same as with the .rb file - just clicked in the menu: when run by .rb the "A" comes up, when run as .rbs nothing happens - no error, nothing at all.
                    I never used so much time on so little code with so little outcome - it feels like just killing time !
                    Best regards
                    KSor, Denmark
                    Skype: keldsor
                      There is something else going on. I tried that Polley snippet you posted - scrambled it. Loaded the .rbs and wrote in the console: x=Polley.new
                      The messagebox popped up.
                      Did you try exactly that small snippet yourself - or did you extract it from your main code? Sounds like your issues lies with the construct of your plugin.
                      Since you don't get any messagebox, nor any errors when it should pop up it sound like something is overriding the initialize method.
                      (Remember you cannot reload a .rbs - you must restart SketchUp to see any changes.)
                        ksor
                        I did EXACTLY that snippet af code - and I start SketchUp from scratch each time I do some tests.
                        I start it as an extension as recommended and this primary code is here:
                        require 'extensions.rb'
                        filename=File.basename(__FILE__)
                        if(not file_loaded?(filename))
                            UI.menu("Plugins").add_item("Remskive") { Sketchup.active_model.select_tool Polley.new }
                        file_loaded(filename)
                        # Create the extension.
                        ext = SketchupExtension.new 'Remskive', 'Remskive/Remskive_LOADER'
                        # Attach some nice info.
                        ext.creator     = 'Keld Sørensen, Danmark'
                        ext.version     = '1.0.0'
                        ext.copyright   = '2012..., Keld Sørensen'
                        ext.description = 'Visit my website; http://kelds.weebly.com/udvidelser.html'
                        # Register and load the extension on startup.
                        Sketchup.register_extension ext, true
                        Best regards
                        KSor, Denmark
                        Skype: keldsor
                          Did you read my previous comment about namespace and loading scrambled files via SketchupExtension?
                            On a sidenote - it can be confusing for the user if the menus are always there - regardless if the extension is loaded. And it'd defeat the purpose of using the extension. Menus should be loaded by the script that SketchupExtension loads.
                              ksor
                              Maybe I misunderstands you - english isn't my first language 😄 - but isn't exactly the opposit of what TIG told me to do ?
                              Best regards
                              KSor, Denmark
                              Skype: keldsor
                                Not quite.
                                The general structure is:
                                Plugins/plugin.rb
                                Defines the SketchupExtension and maybe some constants containing the path of the plugin which the scrambled files can later use.
                                The extension loads Plugins/MyPlugin/loader.rb
                                Loads the rest of the .rbs files. You can define the menus here as well.
                                This proxy unscrambled .rbs file ensures that the content of the rbs files doesn't end up under the SketchupExtension namespace.
                                Putting the menus there also ensures they are not cluttering the UI while the extension is disabled.
                                If the .rbs files need to address the path where the plugin is located they would then refer to the path constant previously defined - withing your own namespace of course.
                                Was that outline somewhat clear?
                                Engelsk er ikke mitt første språk heller. 😉 (Men jeg bodde der i fire år...)
                                  ksor
                                  I think so - but how to implement it if it should NOT be done like I did BEFORE and AFTER TIG made me move my menu settings from/to the primary .rb-file - do you have some sample code ?
                                  Best regards
                                  KSor, Denmark
                                  Skype: keldsor
                                    Plugins/foobar.rb
                                    <span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /></span><span class="syntaxdefault">require </span><span class="syntaxstring">'extensions.rb'<br /><br /><br /></span><span class="syntaxdefault">module Author<br />  module PluginName<br />  <br />  </span><span class="syntaxcomment"># Constants<br /></span><span class="syntaxdefault">  PATH </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dirname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> __FILE__ </span><span class="syntaxkeyword">),</span><span class="syntaxdefault"> </span><span class="syntaxstring">'PluginSupportFolder'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">).</span><span class="syntaxdefault">freeze<br />  <br />  </span><span class="syntaxcomment"># Extension<br /></span><span class="syntaxdefault">  loader </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> PATH</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'loader.rb'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  ex </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> SketchupExtension</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Hello Scrambled World'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> loader </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  ex</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">description </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Lorem Ipsum"<br /></span><span class="syntaxdefault">  ex</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">version </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'1.0.0'<br /></span><span class="syntaxdefault">  ex</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">copyright </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'John Smith © 2012'<br /></span><span class="syntaxdefault">  ex</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">creator </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'John Smith (john@example.com)'<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">register_extension</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> ex</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> true </span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">  end </span><span class="syntaxcomment"># module PluginName<br /></span><span class="syntaxdefault">end </span><span class="syntaxcomment"># module Author  &nbsp;</span><span class="syntaxdefault"></span>
                                    Plugins/PluginSupportFolder/loader.rb
                                    <span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /><br /><br /></span><span class="syntaxdefault">module Author<br />  module PluginName<br />  <br />  </span><span class="syntaxcomment"># Menus and Toolbars<br /></span><span class="syntaxdefault">  unless file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    m </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Plugins'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">...</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br />  <br />  </span><span class="syntaxcomment"># Load the rest of the files - which might be scrambled.<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">;;require(</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">PATH</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'file1'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">;;require(</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">PATH</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'file2'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">;;require(</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">PATH</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">'file3'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">  end </span><span class="syntaxcomment"># module PluginName<br /></span><span class="syntaxdefault">end </span><span class="syntaxcomment"># module Author<br /><br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span>
                                      ksor
                                      Thx - thomthom, I'll study the code carefully !
                                      Best regards
                                      KSor, Denmark
                                      Skype: keldsor
                                      • Dan RathbunD Offline
                                        Dan Rathbun
                                        @ksor said:
                                        @tig said:
                                        The Ruby __FILE__ won't work inside a compiled .rbs file, so that's probably breaking it.
                                        Something is not right here - you say the " __FILE__" won't wotk in .rbs files - NOT TRUE !
                                        [removed 2 code samples - #1 loads OK then #2 does not work after #1 loads]
                                        ... i can't see the principal difference: Can someone pleace tell me why ?
                                        SIMPLE ANSWER (TIG said this, but not so basic...)
                                        In RBS file #1: __FILE__ returns "(eval)" and file_loaded() pushes it onto the $loaded_files array.
                                        When RBS file #2 loads: It uses file_loaded?() to check the $loaded_files array for the value of __FILE__ (which during evaluation of a scrambled script == "(eval)",) AND the value is already found in the array,
                                        .. SO those conditional blocks for ANY RBS file, that you load AFTER file #1, will not create the menu items.
                                        I'm not here much anymore.
                                          Dan Rathbun
                                          On MS Windows...
                                          You can scramble files from the GUI without opening a cmd shell.
                                          Just drag and drop an rb file (from Explorer window 1,) ONTO scrambler.exe (in another Explorer window.)
                                          .. and the rbs file will be put in the original folder with it's rb file.
                                          This may also work with a shortcut icon for scrambler.exe ??
                                          • This works great on XP, Windows 6+ users need to have write permissions the destination folder.
                                            ksor
                                            @dan rathbun said:
                                            On MS Windows...
                                            Oh ... Dan, that was a good one - thx !
                                            I'll implement it right away !
                                            Best regards
                                            KSor, Denmark
                                            Skype: keldsor
                                            • 1 / 3
