    Will NOT scramble ??
    44 Posts 4 Posters 3.9k Views 4 Watching
    • K
      ksor
      When I run this as a rs-file it "works" fine - it comes up in the menu !
      require 'sketchup'
      filename=File.basename(__FILE__)
      if(not file_loaded?(filename))
          UI.menu("Plugins").add_item("Remskive") { Sketchup.active_model.select_tool Polley.new }
      file_loaded(filename)
      class Polley
          # store bogstaver evt. med _ er en CONST
          MINDIAP = 50.mm
          MINDIAA = 10.mm
          MINKRVD = 25.mm
          MINKRVB = 15.mm
      end #class
      when I scramble the file - NOTHING comes up in the menu !
      NO CHANGES except that it's scrambled - why ?
      Best regards
      KSor, Denmark
      Skype: keldsor
        The Ruby __FILE__ won't work inside a compiled .rbs file, so that's probably breaking it.
        You would normally only scramble code you want to remain protected and private.
        Making some menu items is not one of those.
        Why do you want to scramble such a 'simple script'?
        You are hardly protecting your intellectual property rights in the code you showed us...
        Can I suggest that you make a 'loader' script that is a .rb file [which has code the menus/toolbars etc, 'require'ing the main script[s] etc which will be inside your own tool's subfolder - any encrypted .rbs scripts are [usually] kept inside such a subfolder - that's also where any webdialog files, images for toolbar buttons etc will reside...
        Then you have no difficulties setting the menu up via the .rb file AND your code in the .rbs file[s] remains confidential... IF you really have to protect it in this way...
        • K
          ksor
          I just want to try to scramble my code because I (thought I !) can !
          This simple sample is just because I tried to eliminate big chunks of code - and by the first try it went wrong.
          And you'r just right - setting up menues is not something you want to protect - and now I know I CAN'T 😉)
          Best regards
          KSor, Denmark
          Skype: keldsor
            So restructure your toolset as "two scripts"...
            An .rb file in the Plugins folder that will auto-load - making the menus/toolbars etc, and the scrambled .rbs file inside the tool's subfolder, which is what the .rb 'requires', and that makes the 'module/class/methods' called by the .rb items...
              If you do what TIG suggest you can use the opportunity to make it into a SketchupExtension so it's listed in the Extension list.
              • K
                ksor
                Something is not right here - you say the "FILE" won't wotk in .rbs files - NOT TRUE !
                Here is an example and it works fine BOTH as rb- and rbs-file:
                require 'sketchup'
                    UI.menu("Plugins").add_item("Bolte") { Sketchup.active_model.select_tool Bolte.new }
                class Bolte
                    # Konstanter til diverse dialoger og statustekster
                    DIAMETER  = "Diameter      ;"
                    HOVEDTYP  = "Hovedtype     ;"
                    SKIVEVED  = "Skive ved     ;"
                    PLACER    = "Placer ved    ;"
                    KOPI      = "Tilføj kopi   ;"
                    FORFRA    = " ELLER højre-klik for at starte forfra !"
                    NOTONFACE = "Det udprikkede punkt er IKKE på en flade !"
                    UDAFEMNET = "Angiv boltlængden ved at klikke, hvor hjælpelinien kommer ud af emnet"
                    EVTFLERE  = "Vælg evt. flere boltplaceringer, indtast fast boltlængde"
                    SEKSKANT  = "6 Kant"
                    UNBRAKO   = "Unbrako"
                    INGEN     = "Ingen"
                    HOVED     = "Hoved"
                    MOETRIK   = "Motrik"
                    BEGGE     = "Begge"
                    UDMAAL    = "Krydsstreger"
                    KLIKMUS   = "Klik med mus"
                    JA        = "Ja"
                    NEJ       = "Nej"
                	def initialize
                        UI.messagebox("Hertil !",MB_OK)
                end # of class Bolte
                I beleave the code witch started this posting is structured EXACTLY likewise - but it will ONLY run as a rb-file, NOT as a rbs-file - i can't see the principal difference:
                require 'sketchup'
                class Polley
                    MINDIAP = 50.mm
                    MINDIAA = 10.mm
                    MINKRVD = 25.mm
                    MINKRVB = 15.mm
                    def initialize()
                    end #initialize
                end #class
                Can someone pleace tell me why ?
                Both sample codes are cut down to minimal still showing the problem (you can cut out more if you like) - that's why they seems so non sence !
                (>> thomthom: The original files ARE organised as SketchupExtensions - but it's not shown here because I don't think it's part of the problem)
                Best regards
                KSor, Denmark
                Skype: keldsor
                  😒 OK... perhaps I should have said something like using 'FILE' won't work inside a .rbs compiled script consistently...
                  When a Ruby runs it has FILE got from the script's own path, which is unique to each script.
                  When a .rbs runs with the FILE code compiled within it, you cannot assume that it will return the path to the .rbs file itself, so if it's returning the path to the 'executing app' it might just work for one .rbs, but then not for any others subsequently, because FILE will NOT point at the .rbs file itself and will have been added to the file_loaded's array already !
                  I can't see why you are spending so much time trying to compile a 'menu setter' - just make it a .rb - that way it's transparent to the user and won't have these issues, it makes the menu items/toolbars etc and required the .rbs files from their subfolder - it's a 'loader'...
                  Then your compiled .rbs files [without any need to include 'menu code'] can go into your tool's subfolder where they belong with the other files a complex tool needs... This is the 'proper' way to do it... IF you must protect your code by compiling it...
                  At the moment getting you code to run properly is much more important, but if you compile it no one can look at it to help you debug because decompiling a .rbs file is not possible...
                  • K
                    ksor
                    @tig said:
                    :roll: OK... perhaps I should have said something like using 'FILE' won't work inside a .rbs compiled script consistently...
                    When a Ruby runs it has FILE got from the script's own path, which is unique to each script....
                    Ha, ha, I think I'm the one who should do the 😒 😒 😒 !
                    Can I ask (and get an answer of cause ) is the SCRAMBLER just a prototype ?
                    And please don't turn the focus to me trying to scramble menu setting - that's not the point - it's just a smokescreen over the real problem I think.
                    Even this simple code doesn't work when scrambled and loaded as an extension:
                    require 'sketchup.rb'
                    class Polley
                        MINDIAP = 50.mm
                        MINDIAA = 10.mm
                        MINKRVD = 25.mm
                        MINKRVB = 15.mm
                        def initialize()
                    UI.messagebox("A")
                        end #initialize
                        def draw_pulley()
                        end # draw_polley
                        def input_dialog()
                        end # input_dialog
                        def makePulley(diaP, diaA, krvD, krvB)
                        end # makePulley
                    end #class
                    The "A" never comes up 😠 😠 😠 - maybe the scrambler IS a prototype - then just say it then.
                    Best regards
                    KSor, Denmark
                    Skype: keldsor
                      You only need to call
                      once in a session [it might have been called earlier by another script anyway],
                      do should that in your 'loading' .rb file that makes the 'extension'.
                      Then you can omit it from the .rbs because it's already loaded...
                      OR alternatively try to use
                      Sketchup::require 'xxx'
                      inside a compiled script, which should work...
                        The scrambler is not a prototype.
                        It started as @Last's then taken over by Google...
                        So it has been around for many years, but it has always had such issues...
                        But then a few simple ground-rules when devising the set up of your code avoids them.
                        I don't understand your antipathy 😕
                        Either work with what you've been given [taking into account the advice we give freely and kindly], or forget about scrambling things altogether until you are really 'up to steam' on Ruby scripting with the API, OR if you have the ability then write a better scrambler and explain to us how to use it !
                        • K
                          ksor
                          Ha, ha just a new smokescreen ....
                          Whether or not I have the "require 'sketchup.rb'" is not the point - and it has NO difference on the problem !
                          The point is if the scrambler IS a prototype or NOT ... and you have not a single word about it 😒 !
                          I remember to have read somewhere in this forum, that it maybe would be a good idea to write a better scrambler .... I would add: maybe a better interpretor too - not to mention an editor with some intellisence .... that would be really nice.
                          There is much too much 'really low level' debugging going on in what should be a high level language.
                          .... but take Ruby as it is or leave it !
                          Best regards
                          KSor, Denmark
                          Skype: keldsor
                            If you make an extension, using SketchupExtension, which loads a .rbs file you'll get namespace trouble.
                            Say you have a plugin written in module FooBar stored a .rbs loaded via SketchupExtension then it will beloaded into SketchupExtension::FooBar instead of the expected root namespace. I seems that SketchupExtension eval into its own namespace. I ran into that problem with Vertex Tools - and because of that had to make an unscrambled proxy loader to ensure everything came into the correct namespace.
                              So when you do tried Polley.new nothing happened - no error at all?
                              Your example didn't include anything about how you tested it - maybe there is something there.
                              • K
                                ksor
                                I just did the same as with the .rb file - just clicked in the menu: when run by .rb the "A" comes up, when run as .rbs nothing happens - no error, nothing at all.
                                I never used so much time on so little code with so little outcome - it feels like just killing time !
                                Best regards
                                KSor, Denmark
                                Skype: keldsor
                                  There is something else going on. I tried that Polley snippet you posted - scrambled it. Loaded the .rbs and wrote in the console: x=Polley.new
                                  The messagebox popped up.
                                  Did you try exactly that small snippet yourself - or did you extract it from your main code? Sounds like your issues lies with the construct of your plugin.
                                  Since you don't get any messagebox, nor any errors when it should pop up it sound like something is overriding the initialize method.
                                  (Remember you cannot reload a .rbs - you must restart SketchUp to see any changes.)
                                  • K
                                    ksor
                                    I did EXACTLY that snippet af code - and I start SketchUp from scratch each time I do some tests.
                                    I start it as an extension as recommended and this primary code is here:
                                    require 'extensions.rb'
                                    # Create the extension.
                                    ext = SketchupExtension.new 'Remskive', 'Remskive/Remskive_LOADER'
                                    # Attach some nice info.
                                    ext.creator     = 'Keld Sørensen, Danmark'
                                    ext.version     = '1.0.0'
                                    ext.copyright   = '2012..., Keld Sørensen'
                                    ext.description = 'Visit my website; http://kelds.weebly.com/udvidelser.html'
                                    # Register and load the extension on startup.
                                    Sketchup.register_extension ext, true
                                    Best regards
                                    KSor, Denmark
                                    Skype: keldsor
                                      Did you read my previous comment about namespace and loading scrambled files via SketchupExtension?
                                        On a sidenote - it can be confusing for the user if the menus are always there - regardless if the extension is loaded. And it'd defeat the purpose of using the extension. Menus should be loaded by the script that SketchupExtension loads.
                                        • K
                                          ksor
                                          Maybe I misunderstands you - english isn't my first language 😄 - but isn't exactly the opposit of what TIG told me to do ?
                                          Best regards
                                          KSor, Denmark
                                          Skype: keldsor
                                            Not quite.
                                            The general structure is:
                                            Plugins/plugin.rb
                                            Defines the SketchupExtension and maybe some constants containing the path of the plugin which the scrambled files can later use.
                                            The extension loads Plugins/MyPlugin/loader.rb
                                            Loads the rest of the .rbs files. You can define the menus here as well.
                                            This proxy unscrambled .rbs file ensures that the content of the rbs files doesn't end up under the SketchupExtension namespace.
                                            Putting the menus there also ensures they are not cluttering the UI while the extension is disabled.
                                            If the .rbs files need to address the path where the plugin is located they would then refer to the path constant previously defined - withing your own namespace of course.
                                            Was that outline somewhat clear?
                                            Engelsk er ikke mitt første språk heller. 😉 (Men jeg bodde der i fire år...)
                                            • 1 / 3
