    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • K
      katarakt
      How can i see the lines after rounding edges? Here in the pic i've rounded the circle edge but can't see the lines so i have no orientation.
      • GaieusG
        These edges get automatically softened. You can see (and manipulate) softened (and hidden) edges if you turn on hidden geometry under the View menu.
        • K
          katarakt
          Thanks a lot 😄
          Really an excellent plugin!
          • E
            eyein12
            HI! I recently downloaded your plugin but cant seem to get it to work. the icons show in the menu and i can click them but i get an error in the ruby console. I have windows and sketchup 8.3117. I made sure i put the folders where they belong as I have with other plugins. is their a compatability issue? thanks!
            Error: #<NoMethodError: undefined method +' for nil:NilClass> C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174:in +'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Config.rb:148:in selected_folders' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:432:in picture_selected_folders'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:1095:in create_cursor' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:66:in initialize'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in new' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in launch'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:33:in action__mapping' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:132:in call'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:132:in launch_action' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:143:in launch_action'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:159:in startup' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:973:in call'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:973:in command_invoke' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:955:in build_config_commands'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:948:in call' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:948:in add_command'
            C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174:in `call'
            • fredo6F
              There is a known conflict between Matchbox and other plugins (among which mine), because Matchbox redefines some basic Ruby classes.
              There may be a version of Matchbox correcting this issue.
              • N
                nwarner33
                Hi there. I installed what I believe to be the most up to date version of the plugin. I'm using Sketchup 8 pro on a Mac Lion. I tried the plugin on what something that had around 50 edges. Sketchup froze. Tried it a few times actually and every time, it would get to a different point. 90%, 10%, 40% complete. I then tried it on a simple cube. Same problem. I then tried it on one face. 4 edges. same problem. sketch up freezes. does any one have any idea what the problem is and how i can fix it? thanks in advance?
                • C
                  chrisjk
                  What version of LibFredo6 are you running?
                  In which folders have you installed the plugin and library?
                  • K
                    kubusipit
                    I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
                    Jeem
                      mac1
                      Jeem
                      Just happen to see this in passing:
                      1. The way the windows 32 bit memory manager works it splits the memory somewhat equally between the kernel and the program. In addition any device memory ( graphics etc) gets mapped into that a subtracts form the usable memory. Check you task manager and think you will find low memory. Check what you have set for the paging file size and the memory manager will use the hard disk to help that problem but then the PC slows down because of the slower disk. IMO you should install more RAM if possible and is not hard to do just make sure you use an anti static strap.
                      • fredo6F
                        Jeem
                        Just in case, could you open the Ruby console in case messages are displayed when running RoundCorner.
                        There are a few plugins that create incompatibility problems (for instance some versions of Matchhbox and SunPosition). This may also be a source of problem.
                        • C
                          chalky
                          I too have this problem. Lion 10.7.3 - SU v8. Latest Plugins too. Please help 😞
                            sketchdraw
                            only one thing: thank you
                            its amazing
                            • bagateloB
                              bagatelo
                              I have found the fourth icon.
                              Download the attachment and think about.
                              dream.skp
                                janmakowka
                                Hello, I have a problem.
                                Does the corner have to be at a 90 degree angle, or can it be any angle? Because when I try to do it at a non-90 degree angle it goes crazy and does this:
                                I am running windows 7, 32bit. I have 2048mb RAM. All help is appreciated 😄
                                  MaciejS
                                  Hello Everybody
                                  I tried that tool on my model but it doest work correctly, does anybody have an idea what should i do to make all edges and corners smooth ? Help please
                                  http://www.newcolorstudio.pl/valve.jpg
                                  • fredo6F
                                    @maciejs said:
                                    Hello Everybody
                                    Could you post the model, so that we can find out.
                                    I guess this could be done piece by piece (plus duplication x6, as the wheel is symmetrical)
                                      MaciejS
                                      Yes, all parts of the model are symmetrical. All i need is to smooth every edge and make smooth transitions between parts.
                                      here is a link: http://www.sendspace.com/file/1s2pol
                                      • fredo6F
                                        There are several problems with the model:
                                        1. you have hidden internal faces at the ends of the branches of the steering wheel. This is why you cannot select some edges.
                                        2. most corners have 4 edges, and their configurations seems to reach the limit of RoundCorner (4 edges and more are supported, but the algorithm is not very robust)
                                        I think you have to either do the roundings manually or reconsider the design to have corners with 3 edges or try a subdivision with Whaat's Artisan.
                                          MaciejS
                                          Thank you Bro, i am going to fix it manually doing one branch separately and copy as you said. Could you tell me how can i check if my models have hidden internal faces?
                                          • GaieusG
                                            If you make a group and in the entity info box, you cannot see "solid", there may be internal faces (but other errors can also cause this)
                                            You can also use this plugin to remove them:
                                            http://forums.sketchucation.com/viewtopic.php?t=12668
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 74
                                            • 75
                                            • 25 / 75
