    1.5k Posts 477 Posters 4.1m Views 477 Watching
    • fredo6F
      @mechblack said:
      Fredo6, here is the model.
      As evoked, the issue is purely geometrical. The radius of your rounding is too large compared to the shape, so that you will necessarily have overlaps. I could make it work for a rounding of 0.2cm max.
      @mechblack said:
      Fredo6's tool almost works like Solid Works's (Dassault Systèmes). I plan on practicing more with SketchUp this semester. I want to know if there is a cost effective alternative to the giant programs with the giant price tags.
      Solid Works is based on Nurbs. This gives much more flexibility to merge curved surfaces. RoundCorner is purely geometrical and cannot manage the overlap cases.
      Have a good practice
        AcesHigh
        Fredo, this was probably asked before, but I didnt find it in this very long thread. Neither I found the answer in the quick manual.
        Check the image attached... the offset somehow overlaps itself. It happens quite often when I try to use your tool. And when the offset overlaps, it usually results in problems in the end.
        How do I solve this issue?
        • L
          lapx
          How do I get round corner to do this? I thought it would be easy but there are problems.
          roundcorner.skp
          • fredo6F
            Not sure where you want to have the roundings. But it globally works for me (with 1/2"), except in the sharp angle where you may need to reshape locally a la mano.
            roundcorner - lapx - Fredo.skp
            • fredo6F
              @lapx said:
              Thanks Fredo! I was tring to do a 1" radius initially them gave up. I selected the entire chair because I want all edges to be 1" radius. I see you back edge is not rounded. How did you get it to work? I get the red dot in the corner. How do you fix this?
              Most probably, 1" is too large for the rounding in the sharp angle. Remember that this is pure geometry. If you wish to round the edges with any size, you should use another method, for instance Smooth & Divide in Artisan (by Whaat).
                Royal_RnR
                I keep getting this error message.
                Error Loading File __loader.rb
                undefined method `effective_load' for nil:NilClass
                • L
                  lapx
                  Thanks Fredo! I was tring to do a 1" radius initially them gave up. I selected the entire chair because I want all edges to be 1" radius. I see your back edge is not rounded. How did you get it to work? I get the red dot in the corner. How do you fix this?
                  • L
                    lapx
                    This is what i was trying to attempt.
                    http://www.youtube.com/watch?v=3niDglARXdg&feature=related
                    • T
                      TitusKraken
                      im on a mac. i put it into the plugins folder also downloaded the Libfredo but still didnt have the panels even in s7 or s8.
                      pls help, where is the problem?
                      thx
                        Dimethil
                        thx
                        same issue for me on skp pro 6 & 7... any solutions ?
                          Dimethil
                          finally worked for me. I unzipped files in the wrong folder
                          Unzip the folder you downloaded.
                          Move both things inside that folder (another folder called ROUNDCORNER_Dir_xx and a file called ZLoader_Roundcorner.rb) into your Plugins folder.
                          Make sure you have the latest version of LibFredo6 installed, too (there should be a link to it on the same download page.) It contains things that all of Fredo6’s scripts need to work. Download and unzip it, then move its contents (a folder called LIBFREDO6_Dir_xx and a file called LibFredo6.rb) into your Plugins folder.
                          • K
                            katarakt
                            How can i see the lines after rounding edges? Here in the pic i've rounded the circle edge but can't see the lines so i have no orientation.
                            • GaieusG
                              These edges get automatically softened. You can see (and manipulate) softened (and hidden) edges if you turn on hidden geometry under the View menu.
                              • K
                                katarakt
                                Thanks a lot 😄
                                Really an excellent plugin!
                                • E
                                  eyein12
                                  HI! I recently downloaded your plugin but cant seem to get it to work. the icons show in the menu and i can click them but i get an error in the ruby console. I have windows and sketchup 8.3117. I made sure i put the folders where they belong as I have with other plugins. is their a compatability issue? thanks!
                                  Error: #<NoMethodError: undefined method +' for nil:NilClass> C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174:in +'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Config.rb:148:in selected_folders' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:432:in picture_selected_folders'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:1095:in create_cursor' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:66:in initialize'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in new' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in launch'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:33:in action__mapping' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:132:in call'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:132:in launch_action' C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:143:in launch_action'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:159:in startup' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:973:in call'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:973:in command_invoke' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Plugin.rb:955:in build_config_commands'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:948:in call' C:/PROGRA~2/Google/GOOGLE~2/Plugins/LIBFREDO6_Dir_43/Lib6Traductor.rb:948:in add_command'
                                  C:/PROGRA~2/Google/GOOGLE~2/Plugins/MatchboxPlugin/Population.rb:174:in `call'
                                  • fredo6F
                                    There is a known conflict between Matchbox and other plugins (among which mine), because Matchbox redefines some basic Ruby classes.
                                    There may be a version of Matchbox correcting this issue.
                                    • N
                                      nwarner33
                                      Hi there. I installed what I believe to be the most up to date version of the plugin. I'm using Sketchup 8 pro on a Mac Lion. I tried the plugin on what something that had around 50 edges. Sketchup froze. Tried it a few times actually and every time, it would get to a different point. 90%, 10%, 40% complete. I then tried it on a simple cube. Same problem. I then tried it on one face. 4 edges. same problem. sketch up freezes. does any one have any idea what the problem is and how i can fix it? thanks in advance?
                                      • C
                                        chrisjk
                                        What version of LibFredo6 are you running?
                                        In which folders have you installed the plugin and library?
                                        • K
                                          kubusipit
                                          I have the same problem with crash issue. I use Win XP SP 3 with skethup 8. I'm using 2 GB RAM. everytime I applied round corners, my sketchup always crash and shut down. I've tried every setting, it didn't work. Is there any way to solve this problem? I'm totaly confused, whether my XP had something wrong or my Sketchup? thanx for respond.
                                          Jeem
                                            mac1
                                            Jeem
                                            Just happen to see this in passing:
                                            1. The way the windows 32 bit memory manager works it splits the memory somewhat equally between the kernel and the program. In addition any device memory ( graphics etc) gets mapped into that a subtracts form the usable memory. Check you task manager and think you will find low memory. Check what you have set for the paging file size and the memory manager will use the hard disk to help that problem but then the PC slows down because of the slower disk. IMO you should install more RAM if possible and is not hard to do just make sure you use an anti static strap.
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 74
                                            • 75
                                            • 25 / 75
