    [Plugin]FPS Nav
    38 Posts 27 Posters 65.6k Views 27 Watching
      AppleHaven
      Dude, this is wonderful! I've been looking for this for a while, and couldn't understand why it wasn't made yet. It makes getting a feel for the environment so much better. One million thanks! Next step: collision detection?
      • T
        tspco
        Not bad at all, since I am a mouser from way back, it will take some time.
        A joystick would be great if SU supported such a thing.
        Now a question, is there a way to vary the speed of movement, besides normal and fast?
        SU make 2017, /Twilight Render Hobby
        Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
          Jorgensen
          Hi Alan
          Just stubled over your plugin, and what a nice found πŸ˜„
          I have a few questions:
          It is possible to change the 'speedkey' from the right mousebutton to the Shift key like it's normal in games (an some editors)? - right now I often get the context menu when using the plugin.
          I can move while just pressing WASD - I don't need to activate 'shift' wich I find nice πŸ˜„
          Would it be possible to 'activate' your scipt automatic when ever WASD is pressed?
          Or could one activate / deactivate with a shortcut?
            Alan Chatham
            I finally got some time and energy to do a little more work on this plugin, and have made a few little changes -
            -You can now use the numeric keypad to move as well, with 7 and 9 moving up and down
            -Movement speed and mouse sensitivity data is stored across sessions
            Jorgensen, what platform are you running on? I'll look into alternate keyboard shortcuts to use for moving quickly, but at least on Windows 7, shift is needed to prevent the other tools to be selected when using WASD, which sucks, since it tires out the fingers... If there's something different about your platform, I'd love to make it more feature-rich for systems that support it.
            • JClementsJ
              JClements
              Alan,
              So I toggle FPS on. I click on the TopView icon. Next I use one of the arrow keys.
              As soon as I do this the axis rotates 180+ degrees and the camera is no longer looking straight down. Is this the proper behavior?
                Jorgensen
                Hi Alan
                I've just started to play around with Lumion witch uses the WASD+shift combination - just like FPS games, and I find it a very easy way to navigate around the model..... but when I go back to Sketchup it takes some time to get use to navigate the Sketchup way - mousewheel mousewheel mousewheel mousewheel mousewheel.... 😞
                So what I really would like a WASD navigation in Sketchup - and it Should work without I need to activated it by pressing a menu button first.
                That's my dream, but I sure know the limitations of Skethup, and it might not be possible to do at all.
                I use Windows 7.
                Could shiftloc be of any use? - I find the right click mousebutton quite problematic, because the context menu keeps popping up 😞
                Thanks πŸ˜„
                btw - I can't figure out why it's not implemented in Sketchup as default.
                  Michaelv
                  Of course keys are not working on mac. 😍
                  I already have the keys implemented (arrows keys only) and changed the up down movement to > and < and option/command.
                  I also used right double click for speed X10 (which I may reduce)
                  I am planning to use modifier plus arrows for rotating camera up down left right, but rotating around, not rotating the field of view. Working on it.
                    Alan Chatham
                    Let me know how you go, Michael. I'm possibly making some changes to how the camera code works today (it should be minor, but basically it currently creates a new camera and uses that, which means it screws up if you use it in conjunction with panning and tilting, so I want to change that).
                    JClements - That is unintended! It's an unforseen consequence of the mouselook code, which currently clamps the horizontal angle within a certain range. I'll try and get that fixed today.
                      Michaelv
                      I'll modify accordingly once you modify the camera stuff.
                      I'm thinking along these lines:
                      Arrows: pan left/right/backward/forward
                      Option/Command pans down/up
                      Control plus arrows orbits left right, up down
                      <,> changes field of view in and out (but needs a standard reset)
                      Right double click toggles high speed motion/slow speed
                      Also I would not come back to a standard view every time, I'd start with the current camera view, which means the mouse orbit,zoom and pan still work.
                      PMed the current code
                        Stevo
                        Alan, hey this looks like something I've wanted for a while; especially after playing with Lumion. I downloaded the file and put it in my Plugin folder and I still cant get it working. What is the rbz extension? Where do I put it? Sadly I seem to be having a senior moment....urghh and I'm 48!
                        OS/Hardware:
                        Win7 64
                        Sager NP7280
                        i7 980x
                        SLI 460M
                        12gb
                          .rbz is installed under Windows > Preferences > Extensions under SU v8 M2
                          Or just rename the .rbz extension to .zip and unzip it.
                            Stevo
                            Thank you Rich. Alls good, this is a great little Plugin Alan, thank you.
                            OS/Hardware:
                            Win7 64
                            Sager NP7280
                            i7 980x
                            SLI 460M
                            12gb
                              Alan Chatham
                              Thanks! I'm glad you like it!
                                DANSTAZ
                                Hi this is my first post, and i would like to know if you have the time to answer, does this work like a game in terms of say COD where by the camera pans via the mouse (i noticed you said you didn't use a mouse generaly) and the movement is via the wasd keys? THanks for you time and a massive thanks to all the ruby coders.
                                • W
                                  weba
                                  Finally found plugin to allow this, should be like this from the start with, developers never played FPS games?
                                  But, what I'd really appreciate, would be invert-mouse for free look! I'm one of those weirdos who likes that, maybe in the next release...? πŸŽ‰
                                    JuanV.Soler
                                    could it be possible to move an object with the keypad like in Layout ?
                                    Thanks for the plugin ,._)))
                                    Edited : I found this plugin from Jim : http://sketchucation.com/forums/viewtopic.php?t=1530
                                    smart Β‘ thank_you
                                    • B
                                      bigjonyz
                                      Very good effort. if there is a way to reverse the mouse Y axis or sensitivity would be great.
                                      • L
                                        lonherz
                                        @ weba and bigjonyz :
                                        I prefer the y-axis inverted too, and I have obtained this modifying the plugin's code:
                                        • if you have sketchup opened, close it
                                        • open the sketchup's "Plugins" folder
                                        • open the file "FPSNav.rb" in the folder "FPSNav" with a text editor (like notepad++)
                                        • find this line (about at row 343):
                                        yRotationTransformation = Geom;;Transformation.rotation(@FPSNav_eye, horizontalAxis, radiansToRotate)
                                        and change it like this:
                                        yRotationTransformation = Geom;;Transformation.rotation(@FPSNav_eye, horizontalAxis, -radiansToRotate)
                                        (the only difference is a minus before "radiansToRotate")
                                        • save the file and then open sketchup: now the y-axis should be inverted
                                          Jorgensen
                                          Can anyone please explain how (if possible) I can mod the script so
                                          • I can change the navigation to WASD / Q&E without having to use shift?
                                          • use SPACEBAR to doubble speed?
                                          • automatic start WASD navigation just by pressing 'w'?
                                          Thanks πŸ˜„
                                            Jorgensen
                                            bumb πŸ˜„
