    Photoscanned texture
    16 Posts 6 Posters 1.3k Views 6 Watching
    • michaliszissiouM
      michaliszissiou
      Hey, you need a 16 or 32 bit B&W for displacements. Else, expect scaling effect. (commenting Gaieus's idea)
      Once again, the freeware solution is blender. Just unwrap it, (easy in this case) and ask for baking a displacement map.
      Edit: Crazybump!!!
      http://www.crazybump.com/
      The perfect solution. A magical application. Try it. It costs just a little but you have some months to use it as trial.
      This one from the original photo
      Displ from clay render
      AO from clay render
      • oganocaliO
        oganocali
        Actually Gaieus's projection suggestion worked quite nicely.
        Here is the created texture applied to some random shape. (In my haste I left the SU y axis (the green line) in the texture image). I exaggerated the depth map multiplier to 4.
        I am also posting the depth map and the texture as a public donation, no strings attached. Needs extra work for any commercial work.
        • GaieusG
          Well, the idea came from topics that eventually lead to plugins like this:
          http://forums.sketchucation.com/viewtopic.php?t=20635
          or this:
          http://forums.sketchucation.com/viewtopic.php?t=16660
          This is also how I experimented with this method here:
          http://www.thearender.com/forum/viewtopic.php?p=34261#p34261
          • KrisidiousK
            Krisidious
            CrazyBump is awesome... love it.
            By: Kristoff Rand
            • oganocaliO
              oganocali
              I will give crazybump a try.
              • GaieusG
                I have PixPlant. CB is said to be better but it's also more expensive (and PP can also make seamlessly tiling images). At my level of rendering abilities, it is probably all the same.
                • KrisidiousK
                  Krisidious
                  crazy bump is $99/$299 and PixPlant is $195
                  I'd say they're both very proud of their software.
                  By: Kristoff Rand
                  • michaliszissiouM
                    michaliszissiou
                    Here my tests on crazybump.
                    Rendered in cycles/blender, displacement ~300K (the sphere)
                    I also used specular and AO maps.
                    You can test them, use them, I created a fast seamless texture.
                    http://dl.dropbox.com/u/24090090/testCyclesBumps.jpg
                    • oganocaliO
                      oganocali
                      Actually I have been playing with crazy bump today. Real gem. I am amazed at what they can infer from a single picture (not to mention ease of use and speed). Of course the depth map is not accurate but the resulting texture is believable and useable.
                      I marked one problem area,
                      text_crop_DISP.jpg there is a piece of cement that should be sticking out, instead it is given as depression. There is also a dark brown stone that should be sticking out etc. These are minor problems. Ability to remove shadows etc from the diffuse map is great. I think I will eventually purchase CB.
                      • michaliszissiouM
                        michaliszissiou
                        I think so, too.
                        I didn't notice the shade removal. It eliminates these marked problems.
                        Here a more difficult test. A coin. A friend posted a scanned image. His scanner has a very narrow angle for lighting. Difficult then.
                        Another cycles render. Just a low poly cylinder, bumps only, no displacements.
                        Works for distant camera, complicated scenes.
                        http://dl.dropbox.com/u/24090090/coinss.jpg
