    :small apartment:
    18 Posts 8 Posters 1.8k Views 8 Watching
    • marked001M
      marked001
      richard...surprisingly no one mentioned verts! i havent tried to correct these, but this is such a tiny space i'm not sure its even possible to get it looking correct?
      yeah..i mentioned the people and i have no idea why i used the watercolory people.. force of habit and not thinking about the end result..
      http://www.revision21vis.com
      instagram: revi21on
      • RichardR
        Richard
        Jason, no one ever does mention it! Seems to be a SU only acceptance!
        Mate does twilight have a shift lense feature? That is the BOMB for getting verts in such a shot! Play with fire and you can see it realtime to see the camera effect.
        BUILTBRAND.COM.AU
        • L
          ledisnomad
          Nice renderings!
          I'm not great with entourage, myself, so I always "hide" it by adding a little motion blur to them in Photoshop. Makes it look a little like a long-exposure-style photograph.
          • marked001M
            marked001
            I'm pretty sure it does not... and it wont render sketchup 2d perspectives correctly... i typically use the Lens Correction filter in pshop when this is the case..
            instagram: revi21on
            • massimoM
              massimo Moderator
              If you set a two-point perspective in SU and don't move anything (pan, zoom etc.) it does.
              Anyway Thea has a shift lens feature πŸ˜„
              • marked001M
                marked001
                right, yeah...that does work.. and it may have very well worked for this too since you're not looking 'up' like on a building.. maybe i'll give that a whirl.
                instagram: revi21on
                • StinkieS
                  Stinkie
                  clears throat
                  404 Not Found
                  (forums.sketchucation.com)
                  • marked001M
                    marked001
                    you expect me to follow something from 3 years ago?? i do vaguely remember that too.. not sure i ever tried it though..I will now. .thanks.
                    i do have a two point image rendering now though..
                    instagram: revi21on
                    • marked001M
                      marked001
                      verticals! yes yes... much better..
                      instagram: revi21on
                      • massimoM
                        massimo Moderator
                        πŸ‘
                        • massimoM
                          massimo Moderator
                          404 Not Found
                          Did not know that great plugin. Thanks for the heads up Tom. πŸ‘
                          • StinkieS
                            Stinkie
                            You're most welcome. Been using it for years -most handy. I owe whomever made it a pint.
