    :small apartment:
    18 Posts 8 Posters 1.5k Views 8 Watching
    • RichardR Offline
      Richard
      Jason
      Mate did anyone mention verts? And mate the peps aint workin again, first one isn't bad but the second is too posterised and both maybe not posed for the scene.
      BUILTBRAND.COM.AU
      • marked001M Offline
        marked001
        richard...surprisingly no one mentioned verts! i havent tried to correct these, but this is such a tiny space i'm not sure its even possible to get it looking correct?
        yeah..i mentioned the people and i have no idea why i used the watercolory people.. force of habit and not thinking about the end result..
        http://www.revision21vis.com
        instagram: revi21on
        • RichardR Offline
          Richard
          Jason, no one ever does mention it! Seems to be a SU only acceptance!
          Mate does twilight have a shift lense feature? That is the BOMB for getting verts in such a shot! Play with fire and you can see it realtime to see the camera effect.
          BUILTBRAND.COM.AU
            ledisnomad
            Nice renderings!
            I'm not great with entourage, myself, so I always "hide" it by adding a little motion blur to them in Photoshop. Makes it look a little like a long-exposure-style photograph.
              marked001
              I'm pretty sure it does not... and it wont render sketchup 2d perspectives correctly... i typically use the Lens Correction filter in pshop when this is the case..
              instagram: revi21on
              • massimoM Offline
                massimo Moderator
                If you set a two-point perspective in SU and don't move anything (pan, zoom etc.) it does.
                Anyway Thea has a shift lens feature πŸ˜„
                  marked001
                  right, yeah...that does work.. and it may have very well worked for this too since you're not looking 'up' like on a building.. maybe i'll give that a whirl.
                  instagram: revi21on
                  • StinkieS Offline
                    Stinkie
                    clears throat
                    http://forums.sketchucation.com/viewtopic.php?f=81&t=17828&p=143242&hilit=Apartment+Complex+WIP#p143242
                      marked001
                      you expect me to follow something from 3 years ago?? i do vaguely remember that too.. not sure i ever tried it though..I will now. .thanks.
                      i do have a two point image rendering now though..
                      instagram: revi21on
                        marked001
                        verticals! yes yes... much better..
                        instagram: revi21on
                        • massimoM Offline
                          massimo Moderator
                          πŸ‘
                          • massimoM Offline
                            massimo Moderator
                            Did not know that great plugin. Thanks for the heads up Tom. πŸ‘
                            • StinkieS Offline
                              Stinkie
                              You're most welcome. Been using it for years -most handy. I owe whomever made it a pint.
