    [Plugin] OBJexporter v3.0 20130131
    304 Posts 96 Posters 658.4k Views 96 Watching
      @jolran said:
      My guess is that the vertices are not welded.
      Which means that the faces are not attached to each other(big problem in Z-brush).. It is probably not a bug (like having doublettes of vertices), but rather that each face need it's own vertices.
      For ex 2 faces on a cube will share vertexpositions, but not being welded.
      Haven't used this OBJ.exporter. But, I am using Octaine-exporter and havent seen any issues regarding that. Wonder if thoose 2 plugins use the same alogaritm?
      They do use the same algorithms - I wrote both of them ๐Ÿ˜‰
      • michaliszissiouM
        michaliszissiou
        Exactly. I checked it. When removing double vertices in blender they become welded.
        Here a simple skp and the exported tt.obj, a welded in blender obj and a converted to quads one.
        Same not welded issue is happening to collada exports too (1.4)
        For compatibility with zbrush, use these parameters under import palette.
        My wish could be this:
        Close holes (make mess waterproof) / Remove innerfaces(non manifolds) / weld vertices / export obj
        No SU textures / UVs.
        I can do this manually of course.
        tt.skp
        Archive.zip
        • jolranJ
          jolran
          Yeah I know. And if I may add, Octaine render export works very well.
          At least for my needs. Used it all week without any issues.
          Thanks! ๐Ÿ‘ I haven't had any need to use Z-brush for a while but this will come in handy.
          weld vertices
          Sketchup API is a bit restrictive regarding handling of vertices. There is no weld-option of what I can think of. Which means one would have to restructure the whole code to fix a thing like that. I think there was a weld-plugin at smustard if I'm not misstaken.
          I would not mind having some code for welding vertices myself ๐Ÿ˜‰
          • michaliszissiouM
            michaliszissiou
            @jolran
            Just use blender. No need lo learn anything. Just import the obj/edit mode/[W key]/delete double vertices. exit edit mode and export. This will weld all vertices automatically. It's also useful to convert objs to 3ds for nice SU import.
            To eliminate non manifolds/inner faces is more difficult. The ruby plugin works in most cases.
              Here's v1.7 http://forums.sketchucation.com/viewtopic.php?p=294844#p294844
              Material images with no filetype now auto-revert to PNG [possible with Google Earth Snapshots etc].
              [This betters Pro OBJ-exporter which fails in this case]
              Tolerance for deciding if there is a distorted texture relaxed.
              • B
                Ben Ritter
                TIG, thank you again.
                • IdahoJI
                  IdahoJ
                  @michaliszissiou said:
                  @jolran
                  Just use blender.
                  Or Meshlab. http://meshlab.sourceforge.net/ I use this a lot to post process exported .obj files and it works very well. Works on cleaning up manifolds and inner faces as well. Very powerful application. Free too ...
                  Cheers
                  "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
                  • W
                    wongfoon
                    Great work! I have been looking for something similar for a long time.
                    • W
                      wongfoon
                      It works well in most cases. However there seems to be some problem with flipped (mirrored) objects. Half of the object will be black, maybe due to incorrect normals. Try this model http://sketchup.google.com/3dwarehouse/details?mid=dd9ece07d4bc696c2bafe808edd44356&prevstart=0 and you'll see how.
                        Indeed the SKP is made from two mirrored halves as component-instances.
                        Somehow one mirrored version seems to flip the exported faces.
                        The SKP does have some issues with faces reverse - like the windows - but even with those fixed it messes up...Capture.PNG
                        If you explode the parts and export it's all OK...
                        I'll investigate - an instance's transformation SHOULD be properly transferred to any exported faces, obviously it's failing here...
                        However, note this... if I export the OBJ to Octane [that should be using the very same OBJexporter algorithms and code (I wrote both!)] then it renders OK with the two parts intact OR exploded. CaptureO.PNG
                        Only when it's reimported into a SKP does it mess up... However, the Octane OBJ reimported into a SKP displays no flipped face issues either because the materials are on the backs of one half! - just weirder and weirder...CaptureR.PNGCapture2.PNGCapture3.PNG
                        • W
                          wongfoon
                          I am really thankful to your kind and timely response. Similar problems are found with several models downloaded from the warehouse. At this moment I'll try to explode them before exporting, as instructed. So keep up your excellent work!
                            I have found that if a component is 'flipped' the triangulated face loops in the OBJ are returned clockwise rather than counterclockwise, while the vertex normals remain correct.
                            Some apps like Octane [and even my olde OBJimporter] ignore this issue and import it as expected, BUT others like the Fluid-OBJimporter and some other MeshLab type app's baulk at this and make the face 'reversed' with the material on its 'back' so you see 'black' ๐Ÿ˜ฎ ...
                            I need to think of a way to see if an instance is mirrored and then reverse the order of the face's vertices to be ccw...
                            ๐Ÿ˜•
                              Here's v1.8 http://forums.sketchucation.com/viewtopic.php?p=294844#p294844
                              Fixed the recently reported issues with flipped-instance having reversed face vertices.
                              Now any mirrored/flipped instances should have their exported faces' vertices correctly ordered [ccwise]...
                              Although it's probably safest to explode any mirrored instances if you can, as some apps might still be flaky...
                              Fixed up x-wing SKP
                              Renderer OBJexport [with mirroring correction]
                                NOTE: After further testing v1.8 also has issues... so stick with v1.7 till another update is ready ! ๐Ÿ˜ž
                                • W
                                  wongfoon
                                  Is it possible to do this internally within the plugin, to explode and then undo explosion after exporting, as an quick & dirty fix ๐Ÿ˜‰ Hopefully doing so might also fix some other potential tricky issues.
                                    Here's v1.9 http://forums.sketchucation.com/viewtopic.php?p=294844#p294844
                                    Completely has been recoded.
                                    Issues with mirrored-instance's faces being reversed is now fully fixed.Capture.PNG
                                    • IdahoJI
                                      IdahoJ
                                      TIG, thanks a million for the updates! I've been using this plugin quite a bit and it's a real time saver for me ... ๐Ÿ˜Ž
                                      Cheers.
                                        Here's v2.0 http://forums.sketchucation.com/viewtopic.php?p=294844#p294844
                                        The tolerance checks for deciding if it's a 'distorted texture' have been further improved...
                                        • G
                                          gzotti
                                          Hi!
                                          First, thank you for this superb OBJ exporter! I have previously used V1.6 for a large model (about 450.000 triangles mostly from a terrain TIN, counted by Meshlab), which took about an hour to export. The result looked perfect in Meshlab. All other OBJ exporters I tried including the Pro failed on that, so I warmly recommend yours. However, the V2.0 is not finished on the same model after 4 hours. (Win7pro, Core2duo, SU8pro uses 1GB RAM, lots of RAM free.) Was there any big change in the algorithm that causes this? Is it possible to find and try V1.7..1.9?
                                          Kind regards,
                                          Georg
                                            The issue is that any 'mirrored' groups/instances don't export properly with the old versions.
                                            The new version obviously has to do more work to ensure that the nested faces' orientation/UVmapping are now sorted properly in the OBJ code, so it takes longer to complete: unfortunately with Sketchup the processing time gets 'exponentially' longer the more entities there are to be considered - a small file might only takes a second or two longer to complete, but a much larger file WILL take a lot longer to finish...
                                            One way to speed up processing would be to work on a copy SKP, and explode all groups/components before exporting the geometry? Then there'd be nothing to check/explode/heal etc, and therefore less to slow it down...
                                            Here's a copy of the now superseded v1.8 [very similar to v1.6] IF you'd prefer to use that - it IS faster than more recent versions BUT it will give a flawed result with many third-party apps importing the OBJ, IF you have any mirrored instances... You choose...OBJexporter_18.rb
                                            • 15
                                            • 16
                                            • 6 / 16
