    Face camera ANY DIRECTION
    11 Posts 6 Posters 1.5k Views 6 Watching
      jmilton01
      I know nothing about ruby script. However, I hope to change that soon. I was wondering if there is a way to write a plugin that can make a component face the camera no matter its orientation. For example, I can make "Susan" face me as long as I rotate my view left and right (x,y axis). The moment I rotate the view above her, she no longer is facing me. Does anyone have any suggestions as to how to approach this?
      • GaieusG
        Something like this?
        FaceMeTwice.skp
          jmilton01
          YES!
            jmilton01
            How was this accomplished?
            • GaieusG
              One component is nested into another one. One has its blue axis (rotating axis) horizontally while the parent component has it vertically. No need to write a plugin for this.
                jmilton01
                I went this direction earlier this morning. Obviously, I was doing it wrong. Thank you, for your help.
                • GaieusG
                  This was the workflow:
                  1. Made a component just as usually, to face the camera.
                  2. Rotated it so that its blue axis was now horizontal
                  3. Drew a line at one of its edge temporarily, selected both and made a component again to face the camera - but I left its blue axis go up now.
                    (Deleted the extra line later).
                  • gillesG
                    gilles
                    Very smart! πŸ‘
                      DG_kghm
                      Does this workflow still achieve the desired result? I'm trying to create a flat plane that will always have its flat edge face the camera, so that it is basically invisible, yet still casts a shadow. I tried to achieve my shadow casting using this (http://www.sketchucation.com/forums/viewtopic.php?f=15&t=45769) workflow, but was unsuccessful rendering it in Vray, so I'm back here.
                      When I nest the face-me components, only the face-me properties of the parent component are active, unless I open that component for editing, then the nested one starts facing-me. Am I doing something wrong?
                      Thanks folks!
                        Very nice solution! πŸ‘
                        Now place some eyes on that face and watch them follow your every move! puts on tin foil hat
                        • cottyC
                          cotty
                          I wonder what will happen with the use of a third dimension... 😲
                          Nice little DUH?!
                          my SketchUp gallery
