    Model and render this: Glass brick/block
    43 Posts 16 Posters 17.6k Views 16 Watching
    • oganocaliO Offline
      oganocali
      Oppps 😳 sorry.
      Here is 160x160x30 mm version. vray bumpmapped pure glass with texcloth.
        oganocali
          Cyberdactyl
          Hi everyone. As you explore refraction with your rendering software, I urge you to look at it deeper than merely the image you want from behind the glass.
          • HieruH Offline
            Hieru
            That's really interesting and gives me an idea for a scene/model/render.
            www.davidhier.co.uk
            • cheddaC Offline
              chedda
              Here you go Solo, i polished it up a little but i still see geometry in the corners, meh good enough.
              Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
              • HieruH Offline
                Hieru
                Looking really good πŸ‘
                You know you've been overdoing it in Sketchup when the first thing you do when looking at a render is try and orbit to get another view - doh!
                www.davidhier.co.uk
                • cheddaC Offline
                  chedda
                  Thanks Hieru , CG produces strange effects in operators, I get quite introverted I need the radio to stay sane. I had strange scenarios in the outside world after too much battlefield (PS3)
                    jpalm32
                    Pittsburg Glass has SU components & SW for this.
                    • daleD Offline
                      dale
                      Took a stab at it, and it had some definite challenges.
                      But it was fun.
                      Glass block via Artisan. Rendered in Thea.
                      • stefanqS Offline
                        stefanq
                        I did a render long time ago, but I didn't used a glass brick model. It's just a wall( probably out of scale) but it worked for me. Here is the rendering, and the textures I used:
                        • cheddaC Offline
                          chedda
                          Looking good Dale ! Stefanq also good considering it's only textures, is it just 2 faces or do you have internal faces ? Thanks for the textures.
                          • HieruH Offline
                            Hieru
                            I'm still working on mine - I got distracted modelling this - but there are some really ingenious texture only solutions over at the Thea forum.
                            www.davidhier.co.uk
                            • daleD Offline
                              dale
                              Thanks chedda.
                              I also played with this diamond block, but abandoned it as I wanted to "suggest"the figure in the shower, and the diamonds just refracted the image too much.
                              Even the one posted above is not quite subtle enough.
                              Too me this is where it got interesting as using a straight thin glass was too clear, and using a clear glass material had mixed results. I ended up adding a thin film layer in Thea.
                              Hope I get more time to play on this as it is an interesting challenge depending on what you want too see through the refractions.
                              Here is the diamond block image, and the .skp if anybody can ever use it.Glass block diamond 1.pngGlass Block Diamond.skp
                              And here is the wave style.
                              Glass block Wave style.skp
                              • daleD Offline
                                dale
                                Seriously cool lamp! Hope you finish the model.
                                I wonder how using textures v/s modeling mesh alters refracted images behind the block. hmmmm...
                                Hope to get some time to play.
                                • soloS Offline
                                  Another one, this time I used a scene provided by TomDC, first is the original render (Thea BSD) with only one light source (open door) HDRI and second is when a wall is replaced with Glass bricks, incredible amount of light gets sucked through glass wall.
                                  • StinkieS Offline
                                    Stinkie
                                    The first one has issues (then, so do I πŸ˜‰ ), but the second one looks great. How long did these render for?
                                    • soloS Offline
                                      The first one rendered for 12 minutes plus some change at 1200x600 default BSD settings
                                      The second was 33 minutes with a different preset (one of my optimised for thick glass interiors)
                                      • StinkieS Offline
                                        Stinkie
                                        I'm rendering this interior with TR1 as we speak. At 6000 pixels wide and supersampling set at 'High'. πŸ’š
                                        Wonder how long that one'll take. 😲 Ah, if only unbiased rendering were fast -we'd never have to worry about thresholds and the like again. πŸ˜‰
                                        • soloS Offline
                                          Yikes dude! That's an overkill, I'd suggest rendering at size needed and at normal super sampling, that will give a great result, or even high super sampling if you want perfection, but 6000 is crazy.
                                          Unbiased is fast, if you have enough cores or a render farm. πŸ’š
                                          • StinkieS Offline
                                            Stinkie
                                            @solo said:
                                            Yikes dude! That's an overkill, I'd suggest rendering at size needed (...)
                                            That is the size needed. It's a test to see how fast TR1 can deliver me images for printing. And er, you're speaking to someone who's rendered as wide as 20000. πŸ‘Ώ
                                            • 1 / 3
