    Model and render this: Glass brick/block
    43 Posts 16 Posters 17.8k Views 16 Watching
    • cheddaC Offline
      chedda
      Looks excellent Solo. Although they do repeat. You also need the mortar around the block.I guess my other thread is my submission for this challenge.
      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
      • soloS Offline
        Ogan, Those are great but they are not glass blocks, but glass panes.
        These are glass block sizes:
        Inch sizes (actual dimensions, in inches)
        5¾ × 5¾ × 3 7⁄8
        7½ × 7½ × 3¼ or 4
        7¾ × 7¾ × 3 7⁄8
        9½ × 9½ × 3 1⁄8
        11¾ × 11¾ × 3 7⁄8 or 4 inches
        Metric sizes (nominal dimensions, in millimeters)
        160 × 160 × 30
        190 × 190 × 80 or 100
        240 × 115 × 80
        40 × 240 × 80
        • oganocaliO Offline
          oganocali
          Oppps 😳 sorry.
          Here is 160x160x30 mm version. vray bumpmapped pure glass with texcloth.
            oganocali
              Cyberdactyl
              Hi everyone. As you explore refraction with your rendering software, I urge you to look at it deeper than merely the image you want from behind the glass.
              • HieruH Offline
                Hieru
                That's really interesting and gives me an idea for a scene/model/render.
                www.davidhier.co.uk
                • cheddaC Offline
                  chedda
                  Here you go Solo, i polished it up a little but i still see geometry in the corners, meh good enough.
                  • HieruH Offline
                    Hieru
                    Looking really good 👍
                    You know you've been overdoing it in Sketchup when the first thing you do when looking at a render is try and orbit to get another view - doh!
                    www.davidhier.co.uk
                    • cheddaC Offline
                      chedda
                      Thanks Hieru , CG produces strange effects in operators, I get quite introverted I need the radio to stay sane. I had strange scenarios in the outside world after too much battlefield (PS3)
                        jpalm32
                        Pittsburg Glass has SU components & SW for this.
                        • daleD Offline
                          dale
                          Took a stab at it, and it had some definite challenges.
                          But it was fun.
                          Glass block via Artisan. Rendered in Thea.
                          • stefanqS Offline
                            stefanq
                            I did a render long time ago, but I didn't used a glass brick model. It's just a wall( probably out of scale) but it worked for me. Here is the rendering, and the textures I used:
                            • cheddaC Offline
                              chedda
                              Looking good Dale ! Stefanq also good considering it's only textures, is it just 2 faces or do you have internal faces ? Thanks for the textures.
                              • HieruH Offline
                                Hieru
                                I'm still working on mine - I got distracted modelling this - but there are some really ingenious texture only solutions over at the Thea forum.
                                www.davidhier.co.uk
                                • daleD Offline
                                  dale
                                  Thanks chedda.
                                  I also played with this diamond block, but abandoned it as I wanted to "suggest"the figure in the shower, and the diamonds just refracted the image too much.
                                  Even the one posted above is not quite subtle enough.
                                  Too me this is where it got interesting as using a straight thin glass was too clear, and using a clear glass material had mixed results. I ended up adding a thin film layer in Thea.
                                  Hope I get more time to play on this as it is an interesting challenge depending on what you want too see through the refractions.
                                  Here is the diamond block image, and the .skp if anybody can ever use it.Glass block diamond 1.pngGlass Block Diamond.skp
                                  And here is the wave style.
                                  Glass block Wave style.skp
                                  • daleD Offline
                                    dale
                                    Seriously cool lamp! Hope you finish the model.
                                    I wonder how using textures v/s modeling mesh alters refracted images behind the block. hmmmm...
                                    Hope to get some time to play.
                                    • soloS Offline
                                      Another one, this time I used a scene provided by TomDC, first is the original render (Thea BSD) with only one light source (open door) HDRI and second is when a wall is replaced with Glass bricks, incredible amount of light gets sucked through glass wall.
                                      • StinkieS Offline
                                        Stinkie
                                        The first one has issues (then, so do I 😉 ), but the second one looks great. How long did these render for?
                                        • soloS Offline
                                          The first one rendered for 12 minutes plus some change at 1200x600 default BSD settings
                                          The second was 33 minutes with a different preset (one of my optimised for thick glass interiors)
                                          • StinkieS Offline
                                            Stinkie
                                            I'm rendering this interior with TR1 as we speak. At 6000 pixels wide and supersampling set at 'High'. 💚
                                            Wonder how long that one'll take. 😲 Ah, if only unbiased rendering were fast -we'd never have to worry about thresholds and the like again. 😉
                                            • 1 / 3
