    Model and render this: Glass brick/block
    43 Posts 16 Posters 19.2k Views 16 Watching
    • soloS
      First go, I did this with just mesh, no bump, used Artisan to create inside warped mesh.
      Quick Thea render, crepe myrtle tree behind used to show glass warping effect.
      Click on image for larger view
      • cheddaC
        chedda
        Looks excellent Solo. Although they do repeat. You also need the mortar around the block.I guess my other thread is my submission for this challenge.
        Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
        • soloS
          Ogan, Those are great but they are not glass blocks, but glass panes.
          These are glass block sizes:
          Inch sizes (actual dimensions, in inches)
          5¾ × 5¾ × 3 7⁄8
          7½ × 7½ × 3¼ or 4
          7¾ × 7¾ × 3 7⁄8
          9½ × 9½ × 3 1⁄8
          11¾ × 11¾ × 3 7⁄8 or 4 inches
          Metric sizes (nominal dimensions, in millimeters)
          160 × 160 × 30
          190 × 190 × 80 or 100
          240 × 115 × 80
          40 × 240 × 80
          • oganocaliO
            oganocali
            Oppps 😳 sorry.
            Here is 160x160x30 mm version. vray bumpmapped pure glass with texcloth.
            • oganocaliO
              oganocali
              • C
                Cyberdactyl
                Hi everyone. As you explore refraction with your rendering software, I urge you to look at it deeper than merely the image you want from behind the glass.
                • HieruH
                  Hieru
                  That's really interesting and gives me an idea for a scene/model/render.
                  www.davidhier.co.uk
                  • cheddaC
                    chedda
                    Here you go Solo, i polished it up a little but i still see geometry in the corners, meh good enough.
                    • HieruH
                      Hieru
                      Looking really good 👍
                      You know you've been overdoing it in Sketchup when the first thing you do when looking at a render is try and orbit to get another view - doh!
                      www.davidhier.co.uk
                      • cheddaC
                        chedda
                        Thanks Hieru , CG produces strange effects in operators, I get quite introverted I need the radio to stay sane. I had strange scenarios in the outside world after too much battlefield (PS3)
                          jpalm32
                          Pittsburg Glass has SU components & SW for this.
                          • daleD
                            dale
                            Took a stab at it, and it had some definite challenges.
                            But it was fun.
                            Glass block via Artisan. Rendered in Thea.
                            • stefanqS
                              stefanq
                              I did a render long time ago, but I didn't used a glass brick model. It's just a wall( probably out of scale) but it worked for me. Here is the rendering, and the textures I used:
                              • cheddaC
                                chedda
                                Looking good Dale ! Stefanq also good considering it's only textures, is it just 2 faces or do you have internal faces ? Thanks for the textures.
                                • HieruH
                                  Hieru
                                  I'm still working on mine - I got distracted modelling this - but there are some really ingenious texture only solutions over at the Thea forum.
                                  www.davidhier.co.uk
                                  • daleD
                                    dale
                                    Thanks chedda.
                                    I also played with this diamond block, but abandoned it as I wanted to "suggest"the figure in the shower, and the diamonds just refracted the image too much.
                                    Even the one posted above is not quite subtle enough.
                                    Too me this is where it got interesting as using a straight thin glass was too clear, and using a clear glass material had mixed results. I ended up adding a thin film layer in Thea.
                                    Hope I get more time to play on this as it is an interesting challenge depending on what you want too see through the refractions.
                                    Here is the diamond block image, and the .skp if anybody can ever use it.Glass block diamond 1.pngGlass Block Diamond.skp
                                    And here is the wave style.
                                    Glass block Wave style.skp
                                    • daleD
                                      dale
                                      Seriously cool lamp! Hope you finish the model.
                                      I wonder how using textures v/s modeling mesh alters refracted images behind the block. hmmmm...
                                      Hope to get some time to play.
                                      • soloS
                                        Another one, this time I used a scene provided by TomDC, first is the original render (Thea BSD) with only one light source (open door) HDRI and second is when a wall is replaced with Glass bricks, incredible amount of light gets sucked through glass wall.
                                        • StinkieS
                                          Stinkie
                                          The first one has issues (then, so do I 😉 ), but the second one looks great. How long did these render for?
                                          • soloS
                                            The first one rendered for 12 minutes plus some change at 1200x600 default BSD settings
                                            The second was 33 minutes with a different preset (one of my optimised for thick glass interiors)
                                            • 1 / 3
